Energy, magnitude of E & B, pressure from a laser
The discussion focuses on calculating the energy, peak magnetic induction (B), electric field (E), and wave pressure from a Ti-sapphire femtosecond laser with an intensity of 1022 W/cm2 and a spot radius of 1μm. The energy of the laser pulse is determined to be 0.314 J. The relationship between intensity, electric field, and magnetic induction is established using the time-averaged Poynting vector and relevant equations, including I = (c/2μ0)B02 and I = (1/2)cε0E02. The average radiation pressure is calculated using P = (1/2)ε0E02.
  • Understanding of laser physics, specifically Ti-sapphire lasers.
  • Familiarity with electromagnetic wave equations and Poynting vector concepts.
  • Knowledge of energy density and radiation pressure calculations.
  • Basic calculus for integrating Gaussian distributions.
  • Study the derivation and applications of the Poynting vector in electromagnetic theory.
  • Learn about the properties and applications of Ti-sapphire lasers in scientific research.
  • Explore the relationship between electric and magnetic fields in electromagnetic waves.
  • Investigate advanced topics in laser pulse energy calculations and Gaussian beam optics.
Physicists, optical engineers, and students studying laser technology and electromagnetic theory will benefit from this discussion.
darkfall13
A Ti-sapphire femtosecond laser (1fs= 10^-15s, λ≈0.8μm) has an intensity of 1022 W/cm2
when focused to a spot of 1μm radius. What is the energy of the laser pulse? What is the peak
magnetic induction B in Tesla and the electric field in V/m? What is the wave pressure in
atmospheres?
[tex]P = \int I da = \frac{E}{\Delta t}[/tex]
[tex]E=cB[/tex]
I've solved the first part
[tex]P = IA = 10^{22} \frac{W}{cm^2} \pi \left(1 \mu m\right)^2[/tex]
[tex]= 3.14 \times 10^{14} W[/tex]
[tex]E = .314 J[/tex]
But what is the relationship of what was given to either ]E or B? The only equations I can find are sinusoidal with the assumption that [tex]E_0[/tex] or [tex]B_0[/tex] are known to find their values at a particular time. Would I take the pulse with the assumption that B and E = 0 and the beginning and end and the information of the wavelength to find the value it peaks at? Now that I'm thinking of that, I'd still need some sort of E_0 or B_0.
Assuming you have done the first part correct (if the question suggests it, you may need to integrate a gaussian distibution to get the power instead of just using the area of a circle)... anyway, to answer your question. The irrandiance [itex]I[/itex] relates to both the electric field [itex]E[/itex] and the magnetic induction [itex]B[/itex] through its definition as the time averaged Poynting vector:
[tex] I \equiv \left\langle S \right\rangle = \frac{c^2\epsilon_0}{2}\left\vert E_0 \times B_0 \right\vert[/tex]
So that:
[tex] I = \frac{c}{2\mu_0}B_0^2[/tex]
[tex] I = \frac{1}{2}c\epsilon_0 E_0^2[/tex]
The "average" radiation pressure is given by the energy density of the wave (note the units energy/volume and force/area are the same)
[tex]P = \frac{1}{2}\epsilon_0 E_0^2[/tex] (this will give answer in Pascals though using previous units)
Hope this helps...
That does help immensely thank you.
42K
