Energy, time and length corresponding to mass of electron.
The discussion centers on calculating the energy, time, and length corresponding to the mass of an electron using quantum electrodynamics (QED) principles. The mass of the electron is established as 9.11E-31 kg, leading to an energy calculation of 0.511 MeV using the equation E=mc². Length is derived as 386 femtometers (fm) using the relation c * hbar = 197 MeV * fm, while time is calculated as 1.288E-21 seconds using hbar = 6.58E-22 MeV * s. The discussion highlights the importance of conventions in using the reduced Planck constant (hbar) versus the Planck constant in these calculations.
  • Understanding of quantum electrodynamics (QED)
  • Familiarity with the mass-energy equivalence principle (E=mc²)
  • Knowledge of Planck's constant and reduced Planck constant (hbar)
  • Basic concepts of particle physics and units of measurement (MeV, fm)
  • Research the de Broglie wavelength of an electron for comparative analysis
  • Study the conventions in quantum mechanics regarding the use of Planck's constant
  • Explore the implications of using natural units in particle physics calculations
  • Learn more about quantum electrodynamics and its applications in modern physics
Students and researchers in physics, particularly those focusing on quantum mechanics and particle physics, will benefit from this discussion. It is also valuable for anyone looking to deepen their understanding of energy-mass relationships and fundamental constants in QED.
H_Psi
Hey,
I am starting to learn the basics of QED and I am trying to get acquainted with the units and scales that are used.
The exercise is to estimate the energy, time and length that correspond to the mass of an electron.
That’s what I did:
The mass of an electron is 9.11E-31 kg.
Energy:
E=mc^2 gives me an energy of 0.511MeV.
Length:
Here I used the equation: c * hbar = 197 MeV * fm
-> 386fm = c * hbar / (0.511MeV)
-> In natural units: 386fm = 1 / (0.511MeV)
Time:
Here I used the equation: hbar = 6.58E-22 MeV * s
-> 1.288E-21 s = hbar / (0.511MeV)
-> In natural units: 1.288E-21 s = 1 / (0.511MeV)
Is this calculation correct? Is that the way one can calculate the length and time corresponding to a mass?
Thanks
Makes sense, but I'd take a look at the equation you used to find the length. Do you really want to be using the reduced Planck constant (hbar) there, or simply the Planck constant (2*pi*hbar)? You can look up the de Broglie wavelength of an electron, and you'll see your value is a bit small.
That depends on the convention, right? For instance, in Peskin, the convention is to use hbar as the base unit (of action). I don't recall seeing anyone use just plane h as the base unit, but it is just a convention.
  • · Replies 24 ·
30K
