Engineering Statics Problem - Determining Magnitudes
The discussion revolves around solving a statics problem involving two cables supporting a 1500N load. Participants emphasize the importance of applying equilibrium conditions, specifically summing forces in the x, y, and z directions to find the magnitudes of the unknown forces. There is confusion regarding the application of vectors and the concept of moments, with suggestions to focus on scalar components instead. The 1500N force is clarified as acting at point A, which is crucial for setting up the equations. Overall, the conversation highlights the need for a solid understanding of vector notation and equilibrium principles to tackle the problem effectively.
deathcap00
Two cables are used to secure the overhang boom in position and support the 1500N load. If the resultant force is directed along the boom from point A towards O, determine the magnitude of F_C(FsubC), F_B, and the resultant force, F_R. Set x= 1 and z= 4 .
I am not catching on very quickly in my statics class so my notation is probably messed up. Thanks for the help!
What are you trying to achieve by computing Fac = Fc - Fa? There is no Fa shown on your diagram, and no Fac nor Fab shown. I guess I do not understand what you are doing yet, or why. And why did you write Fr = Fb + Fc? That is also a false statement. What about using equilibrium?
Your work is not quite right. It asks you to find the magnitudes of the forces. So what you have to do is split your forces up in x,y, and z components. And also sum the moments about a particular point.
Cross products may be easier in this case.
Try again.
That is the problem, I don't know what I am doing, just need some guidance on where to start.
Well all of your forces have components along the x, y and z axes. You should know from class that \sum{\vec{F}}=0 is the equilibrium condition. Split that up into scalar components and you have \sum{F_x} =0
\sum{F_y} =0
\sum{F_z} =0
And the same goes for moments.
Just a hint: When they ask you to find the magnitude of something, you usually don't need to use vectors. Unless its easier that way, but your final answer is never a vector.
We haven't learned about equilibrium yet, so I am not sure about that.
Try again.
We haven't been taught about moments or cross products yet either. I think I understand about splitting the x,y,z components up, but the 1500N force doesn't "terminate" anywhere so how do I determine that? Also, wouldn't I need one of the forces of AC or AB to determine the resultant force? Thanks for the help, I am determined to get this problem...
So if magnitude is asked for, what are the general beginning steps to get your answer?
\sum{\vec{F}} = 0 IS equillibrium.
I do not know what you mean by terminate.
You could start by rereading posts #3 (save for moments) and #5. I am sure you know what vectors and their scalar components are.
Simply by looking at the diagram the only forces that have any contribution in the z direction are the 1500N, Fb and Fc. This should get you started.
bad post
How do I incorporate 1500N into the process? Don't one of the other cables need a value in Newtons for me to calculate? By terminate, I meant that the 1500N force isn't anchored on one end so I don't know how to use that value in my calculations. Hopefully, that clears it up...
You have a few misunderstandings you need to get rid of.
First of all the 1500N force vector is clearly given to you. namely (-1500 \vec{k}) N Study vectors again. Any vector along a x,y,z axes, given its magnitude will only have the directions, i,j or k respectively.
You should also learn the difference between a vector and a scalar.
Read these: http://en.wikipedia.org/wiki/Euclidean_vector
http://en.wikipedia.org/wiki/Moment_(physics )
Do that and restudy your class notes and your textbook.
deathcap00: The 1500 N applied load terminates at point A. Start by using equilibrium. In your case, that means summation(Fx) = 0, summation(Fy) = 0, and summation(Fz) = 0. Or, if you want to use vector notation (i, j, k), that is perfectly OK (your choice), in which case the above would be summation(F) = 0.
Start by writing the above equations. Include the unknowns. You have three unknowns. Solve the equations simultaneously for the three unknowns. You do not need summation of moments. Try it again.
Thanks to all for the help, I will try and work this problem again this evening with the provided help info. Sorry if I am not that smart about this stuff, I am taking Statics for the first time and vector calc too so it's all very new to me and I am having a hard time getting some of the concepts down the first time around. Hopefully, I will be able to help someone on here one day! Thanks again, I will post and let you guys know how it goes.
