Engineering Statics (Vector Questions)
  • Thread starter Thread starter xtrubambinoxpr
    Engineering Statics
The discussion revolves around a problem in engineering statics, specifically focusing on vector components and the use of the parallelogram method for vector addition. Participants are exploring how to accurately represent forces and their components relative to defined axes.
  • Participants discuss the challenges of drawing a parallelogram for vector addition and seek advice on alternative methods, such as breaking vectors into components. There is also consideration of angle relationships in triangles formed by the vectors.
The conversation is ongoing, with participants providing insights into the relationships between angles and components. Some guidance has been offered regarding the use of trigonometry to find components relative to the defined axes, but there is still uncertainty about applying these methods to new images presented.
Participants are working under the constraints of a specific problem setup that defines axes and requires the use of the parallelogram law for vector addition. There is mention of difficulties in visual representation affecting the understanding of the problem.
xtrubambinoxpr
Attached below
I am having a problem because the solutions manual does the parallelogram method and stupid me I cannot draw the parallelogram correctly. Specifically my drawings are off a bit. and it throws me off every time. the last one I had vector (FR) completely wrong because the damn figure.
I attempted to draw a parallelogram but i suck at it and want some advice / help. If anyone has any suggestions. I am better on doing it into components but how would you do this in components being the axis is slanted.
They defined the axis for you in this problem, and want you to find the components of the force relative to those axis. So what you can do is find the angle the force makes with respect to the u-v axis and use trig to find the components.
so would i be right to say the right side has a triangle with degree measures 45, 30(alt interior angles, and 105?
If I understand you correctly, you're saying that the angle F1 makes to the v-axis is 45degrees?
well 180 in a line.. so 180 - 105 = 75.. for the "quadrant III" let's say.. opposite is 75 total.. but you have 30 given. so that makes the extra angle left 45. so the alt interior angle tells me that there will be a 45, 30, 105 triangle
Correct. From that you can find the angle F2 makes relative to the v-axis as well and from that you can determine the components of the force with respect to the u-v axis.
Ok cool thanks! One last question
The new image I attached is so blank. Would I use the same method?
Hmm, I'm not quite sure on this one, I would say no but don't take my word for it. What I would consider though is using the parallelogram law to create a force triangle. I can't really offer any tips on it, just draw A+B, then translate them accordingly to make the parallelogram.
  • · Replies 46 ·
