How Did Engineers Construct Submerged Tunnels Like BART's?
Engineers construct submerged tunnels like BART's by drilling through bedrock and reinforcing them with concrete sections arranged in an arch. These tunnels are designed to withstand significant water pressure, ensuring structural integrity. In some cases, sections can be prebuilt and lowered into place, with water pumped out afterward to create a dry tunnel. The use of gravel and rock helps stabilize these underwater structures. The engineering behind such designs showcases the remarkable capabilities of modern construction techniques.
CrossFit415
How did engineers manage to build tunnels submerged 100 ft under water without having tunnels collapsing? Say for example, BART, has trains going through these tunnels daily. How did engineers build water tunnels?
Well my guess would be similar to how they build a submarine and not have it collapse.
I'm not sure what BART is, but most tunnels are drilled through bedrock (http://en.wikipedia.org/wiki/Tunnel_boring_machine) with concrete sections inserted in an arch arrangement to act as reinforcement for the tunnel.
The basics being you simply create a tunnel which is strong enough to withstand the required pressure.
If the tunnel was not drilled, you could create sections and lower them to the bottom of the water and once completed (and as such waterproof) you could simply pump the water out to leave you with a tunnel.
I see thanks. Oh BART stands for Bay Area Rapid Transportation located here in Bay Area, California
Yes, I did a bit of Googling to see if they showed whether it was above the bottom of the water or below in bedrock. Apparently not so I can't be more specific in the reply.
I did research and engineers prebuilt the tunnel to be submerged under water after completion. By using gravel and rock its holding down the tunnels.
I just thought I found this facsinating. Very interesting to see what we can design. We can design anything we see.. incredible.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
