Enthalpy Change in Dissolving Ammonium Nitrate in Water
In summary, the coffee cup calorimeter found that the process of dissolving solid ammonium nitrate in water is endothermic.
louise82
A coffee cup calorimeter can be used to investigate the process that occurs when solid ammonium nitrate dissolves in water:
NH4NO3 (s) --> NH4+ (aq) + NO3 – (aq)
25.0 g of solid NH4NO3 at 23.0 degrees C is added to 250.0 mL of H2O at the same temperature, and after the solid is all dissolved the temperature is measured to be 15.6 degrees C. Calculate the enthalpy change (in kJ/ mol NH4NO3) for this process. Assume that the density and specific heat capacity of the solution are the same as for water. Is the process endothermic or exothermic?
(I think): q=(c) x (m) x (change in temp)
qsol + qrxn = 0 (or) -qsol = qrxn
? I do know that the specific heat for water is 4.184J/g degrees C and its density is 1.000g/mL
:confused:
And I think its endothermic since the temp change is positive.
Alright let's think this through, I'm studying enthalopy changes right now so I'm going to give this a try:-p
You're right about the equation:
"H = mass*C (or specific heat capacity)*Change in Temp"
I honestly haven't heard of the second equation you mentioned but I know I can solve this problem with just the first equation
So in this case:​
Mass=Total volume of the solution= 25g(NH4NO3) + 250g(H2O)= 275g (Solution)
**You know that 1g of water is equal to 1mL of water**
C = 4.184 J/g*C
Change in Temp = 15.6 deg - 23 deg = - 7.4
Now multiply the mass*C*Change in Temp=
275g*4.184(J/g*C) *-7.4 = -8 514.44 J = -8.51444KJ
That is -8.51444 KJ per 25g of NH4NO3. But the question is asking for the # of J for every mole of NH4NO3. So we have to find how many moles of NH4NO3 there are in 25g usinf the molar mass of NH4NO3:
25g*(1mol/80g) = 0.3125 mols
Now we know that it's -8.51444 KJ for 0.3125 mols ,divide and you get -27.246208 kJ/mol of NH4NO3
As for it being exo or endo -thermic, i'd say it's exothermic, or it released heat energy (think of it this way it had 23deg and it gave away a bunch of heat till it reached 15.6 deg) Another way you know this is b/c the final enthalapy change is negative, and another rule is that if the enthalapy change is neg then it's exothermic, positive and it would be endothermic
**Remember Change in Temp= Temp Final(or 15.6 deg) - Temp Initial (23 deg) = - 7.4
Hope that helps!:smile:
Thanks, that helped a lot!
It's endothermic...
Yeah, it is endothermic. I realized I was solving the problem for the solution instead of the the reaction. So, it ended up being 27kJ/mol. Thanks so much for the help though. I have only seen one problem worked in class.
Just for clarification: since the enthalpy change for the solution was negative, does that mean it IS an exothermic reaction for the solution, but an endothermic reaction for the reactants?
Endothermic means that heat is absorbed by the reaction. Exothermic means heat is produced. What will the sign of enthalpy be for heat absorption? For heat produced?
Heat absorbed, enthalpy change should be positive. Heat released, enthalpy change should be negative?
What is giving me problems, is that when I work the problem, (as done in the previous post), it comes out to be -27kJ/mol. But, when I looked up the enthalpy in my textbook, it is listed as positive 27kJ/mol. How do I account for the sign change?
I think the temperature change definition should be
Temperature (initial) - Temperature (final) = Temperature change
Tf - Ti is the definition. Exothermic means that heat is given off, or if not allowed to escape from the system, raises the system temperature; endothermic means that the system temperature decreases, and the system can absorb heat from the surroundings. The sign of the heat is that for heat absorbed by the system to return it to its initial temperature.
Related to Enthalpy Change in Dissolving Ammonium Nitrate in Water
1. What is enthalpy change in a coffee cup?
Enthalpy change in a coffee cup refers to the amount of heat that is either gained or lost when a chemical reaction takes place within the cup. In simpler terms, it is the measure of the change in energy of the coffee cup due to a chemical reaction.
2. How is enthalpy change in a coffee cup measured?
Enthalpy change in a coffee cup is typically measured using a device called a calorimeter. The calorimeter consists of an insulated container, a thermometer, and a stirrer. The change in temperature of the coffee cup is recorded before and after the reaction, and the difference is used to calculate the enthalpy change.
3. What factors can affect the enthalpy change in a coffee cup?
The enthalpy change in a coffee cup can be affected by several factors, including the amount and type of reactants used, the temperature of the reactants, and the pressure and volume of the cups. Other factors like the presence of a catalyst or the rate of stirring can also have an impact on the enthalpy change.
4. What is the significance of enthalpy change in a coffee cup?
Enthalpy change in a coffee cup is important because it provides insights into the energy changes that occur during a chemical reaction. It helps scientists understand the thermodynamics of the reaction, which can have practical applications in industries such as food and beverage, pharmaceuticals, and energy production.
5. Can enthalpy change in a coffee cup be negative?
Yes, enthalpy change in a coffee cup can be negative. A negative enthalpy change indicates that heat is being released from the reaction, resulting in a decrease in the temperature of the coffee cup. This is often seen in exothermic reactions, where the products have lower energy than the reactants.
  • Biology and Chemistry Homework Help
19K
22K
