Enthelpy of vaporization of hexane
  • Thread starter Thread starter ricard.py
    Vaporization
The discussion focuses on estimating the enthalpy of vaporization (ΔHvap) of hexane using the Clausius-Clapeyron equation. The normal boiling point of hexane is 69.0°C, and the user initially calculated ΔHvap as 34 kJ/mol, while the expected value is 29.1 kJ/mol. The discrepancy arises from the assumption that ΔHvap is temperature-independent and the ideal gas behavior of the vapor phase. To improve accuracy, it is suggested to use a reference point closer to the boiling point of hexane.
  • Understanding of the Clausius-Clapeyron equation
  • Knowledge of thermodynamic concepts such as enthalpy and boiling points
  • Familiarity with the properties of hexane
  • Basic principles of ideal gas behavior
  • Research methods to obtain accurate boiling point data for hexane
  • Learn about the limitations of the Clausius-Clapeyron equation
  • Explore alternative methods for calculating enthalpy of vaporization
  • Investigate the impact of temperature on enthalpy calculations
Chemistry students, thermodynamics researchers, and professionals involved in chemical engineering or physical chemistry who are interested in vaporization processes and enthalpy calculations.
ricard.py
The normal boiling point of hexane is 69.0°C. Estimate (a) its enthalpy
of vaporization
In order to solve for ΔHvap in the Clausius-Clapeyron equation I need a reference T and p point. I extracted it from the triple point (T=178K and p=1,23Pa).
I solve and I get 34kJ/mol, while the answer is 29,1kJ/mol. What I've done wrong?
Thanks!
The Clausius-Clapeyron equation is just an approximation, because it is assumed in deriving it that the enthalpy of vaporization is temperature independent and that the gas phase behaves as an ideal gas. Like it's said in the question, you are only expected to give an estimate, anyway.
So how would you do to get a more accurate result? One option is to get a (T,p) point closer to the desired 69ºC and 1bar, but if this is not available...?
