Entropy in a non inertial reference frame
The discussion centers on whether entropy remains consistent across non-inertial reference frames, similar to its behavior in inertial frames. Participants explore the implications of observing a system's entropy from a rotating frame versus a fixed frame. The consensus leans towards the idea that entropy should remain the same in non-inertial frames. However, the complexities of non-inertial effects on thermodynamic properties are acknowledged. Ultimately, the belief is that entropy is invariant even when viewed from different reference frames.
hgandh
I know that the entropy of a system is the same in different inertial frames. Is this still the case for non inertial frames? For example, is the entropy of a body as seen from a rotating reference frame the same as the entropy seen from a fixed frame?
Science news on Phys.org
I think yes, it is same in noninertial frames.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
