How Does Heat Transfer Between Two Reservoirs Affect Universal Entropy?
  • Thread starter Thread starter gboff21
    Entropy Universe
The discussion revolves around calculating the entropy change of the Universe when 100 J of heat is transferred from reservoir H at 900 K to reservoir C at 300 K. The correct formula for entropy change is applied, using ΔS = ∫dQ/T, leading to the calculation of ΔS_universe as the sum of the entropy changes of the surroundings and the system. There was confusion regarding the temperature of reservoir C, initially stated as 200 K but later corrected to 300 K. The final entropy change calculation simplifies to 2/9, confirming the correct approach. The conversation highlights the importance of accurate temperature values in thermodynamic calculations.
gboff21
Two large reservoirs, H and C, are available: if H is at 900 K and C is at 300 K, what is the
entropy change of the Universe if 100 J of heat are taken from H and added to C?
ΔS=∫dQ/T
ΔS_universe = ΔS_surroundings + ΔS_system
so it's just (-100/900)+(100/300) = 9/2 right? Just checking!
ΔS=∫dQ/T
so it's just (-100/900)+(100/200)
I think that's the right approach. But isn't C at 300 K (not 200)?
I think you might have inverted something.
Sorry that 200 has been corrected to 300
Okay, so we have...
Okay, that looks correct. :approve:
= 9/2 right?
Wait, what?
Try that simplification one more time. :wink:
Sorry it's 2/9
