EoM via varying action - covariant derivative when integrate
The discussion revolves around the use of covariant derivatives in the context of integrating actions in general relativity, particularly when performing integration by parts. Participants explore the implications of using the determinant of the metric, denoted as ##\sqrt{g}##, and how it affects the integration process and the transformation properties of tensor components.
  • One participant questions whether the covariant derivative must replace the partial derivative when integrating by parts with the factor ##\sqrt{g}##.
  • Another participant asserts that the covariant divergence of a scalar density equals the partial divergence, suggesting a trade-off between the two derivatives in certain cases.
  • A detailed example is provided, showing how integration by parts leads to expressions involving covariant derivatives and Christoffel symbols, emphasizing the need for coordinate invariance.
  • There is a discussion about the signature of the metric and its effect on the determinant ##g##, with some participants clarifying that for Lorentzian spacetimes, ##\sqrt{-g}## is used consistently regardless of signature conventions.
  • Concerns are raised about the implications of contracting indices between tensors and the necessity of using covariant derivatives to maintain coordinate invariance.
  • One participant expresses confusion regarding the treatment of tensors with the same number of indices and the implications for integration, leading to a clarification that the integrand must be a scalar.
Participants generally agree on the need for covariant derivatives in certain contexts but express differing views on specific applications and implications, particularly regarding the treatment of indices and the nature of the integrand. The discussion remains unresolved on some technical points, particularly concerning the integration of tensors with the same number of indices.
Limitations include the dependence on the definitions of the metric signature and the nature of the integrand. The discussion does not resolve the mathematical steps involved in integrating tensors with multiple indices.
binbagsss
##\int d^4 x \sqrt {g} ... ##
if I am given an action like this , were the ##\sqrt{\pm g} ## , sign depending on the signature , is to keep the integral factor invariant, when finding an eom via variation of calculus, often one needs to integrate by parts. When you integrate by parts, with this integration factor, is it now, always, the covariant derivative, replacing the partial derivative as in normal calculus when integrating by parts ? ..
I'm not sure I get the question .but by definition the covariant divergence of a scalar density equals the partial divergence. So one can trade partial for covariant derivatives and vice versa in that case.
If I am understanding the question correctly, you are looking for something of the form
\int d^4x \sqrt{g} A^\mu \partial_\mu f,
where you want to do partial integration. Partial integration will always give you
- \int d^4x f \partial_\mu(\sqrt{g} A^\mu),
which you can rewrite
- \int d^4x \sqrt{g} f \left[ A^\mu \frac{1}{\sqrt{g}}\partial_\mu\sqrt{g} + \partial_\mu A^\mu\right].
Noting that ##\Gamma^\nu_{\mu\nu} = \partial_\mu \ln(\sqrt{g})##, it follows that
\int d^4x \sqrt{g} A^\mu \partial_\mu f = - \int d^4x \sqrt{g} f [A^\mu \Gamma^\nu_{\mu\nu} + \partial_\mu A^\mu]
= - \int d^4x \sqrt{g} f \nabla_\mu A^\mu.
If this is what you mean by having to use the covariant derivative (keeping the ##\sqrt{g}## factor out of it), then yes.
Note that if you have other indices contracted inside ##f## or ##A^\mu## they will not matter. If you have additional indices that are contracted between ##f## and ##A##, then you should have the covariant derivative from the beginning or your expression would not be coordinate invariant. The integration by parts for those indices does not change the sign of the corresponding Christoffel symbol - which gives the relative sign between the terms that you need to go from the covariant derivative of one part to the covariant derivative of the other. For example (just writing out the integrand apart from ##\sqrt g##)
A^\mu_\nu \nabla_\mu f^\nu =
A^\mu_\nu (\partial_\mu f^\nu + \Gamma_{\mu\lambda}^\nu f^\lambda) \to
(-\partial_\mu A^\mu_\nu - \Gamma^\mu_{\mu\lambda} A^\lambda_\nu + \Gamma_{\mu\nu}^\lambda A^\mu_\lambda) f^\nu
= -(\nabla_\mu A^\mu_\nu) f^\nu.
As before, the ##\Gamma_{\mu\lambda}^\lambda## came from the differentiation of ##\sqrt{g}## after the partial integration. The second term was not partially integrated (it contains no derivative) and therefore did not switch sign.
binbagsss said:
were the ##\sqrt{\pm g}## , sign depending on the signature
If you mean the signature convention you adopt for the metric (timelike ##+---## vs. spacelike ##-+++##), it doesn't. For a Lorentzian spacetime, the determinant ##g## of the metric is always negative, so you always have ##\sqrt{-g}##.
To be a little more specific, in an even-dimensional Lorentzian manifold, it does not depend on the signature convention.
Orodruin said:
Note that if you have other indices contracted inside ##f## or ##A^\mu## they will not matter. If you have additional indices that are contracted between ##f## and ##A##, then you should have the covariant derivative from the beginning or your expression would not be coordinate invariant. .
Thank you I think your post helped a lot
But why is this ?
But why is this ?
Why is what? The case of indices contracted between ##f## and ##A^\mu##? I thought my example with a single index contracted between them would address that. More indices contracted between them are just writing more terms with Christoffel symbols.
no , sorry, the coordinate invariant part
haha ofc, apologies !
That is no more difficult than the partial derivative of a tensor component not having the correct transformation properties. You need the covariant derivative for that.
I just came across this and it was extremely useful but I'm having an issue when the number of indices on the two tensors is the same. For example, (in the integral)
\begin{align*}
\sqrt{g}A^{\mu}\nabla_{\nu}B^{\rho} &= \sqrt{g}A^{\mu}\partial_{\nu}B^{\rho} + \sqrt{g}A^{\mu}\Gamma_{\nu\sigma}^{\sigma}B^{\rho} \\
&= -\sqrt{g}\left( \frac{1}{\sqrt{g}}\partial_{\nu}\sqrt{g}A^{\mu} + \partial_{\nu}A^{\mu} - A^{\mu}\Gamma^{\sigma}_{\nu\sigma} \right)B^{\rho}\\
&= -\sqrt{g}\left( A^{\mu}\Gamma^{\sigma}_{\nu\sigma} + \partial_{\nu}A^{\mu} - A^{\mu}\Gamma^{\sigma}_{\nu\sigma} \right)B^{\rho}\\
&= -\sqrt{g}(\partial_{\nu}A^{\mu})B^{\rho}
\end{align*}
When, of course, I would expect
\sqrt{g}A^{\mu}\nabla_{\nu}B^{\rho} = -\sqrt{g}(\nabla_{\nu}A^{\mu})B^{\rho}
Can you please explain what I'm missing or doing wrong?
You cannot have the same number of indices as your integrand is not a scalar then. Alternatively you have to integrate over a hypersurface instead but it is not clear to me exactly what you want to do.
That makes a lot of sense, thanks. I was just thinking about it in a general sense and honestly just failed to consider that, but I now realize that was a foolish oversight. Thanks a lot!
  • · Replies 32 ·
