Epsilon-delta proof for a limit of a troublesome function
thenthanable
limx→01/(x2-1)=-1
0<|x|<δ and |((1/(x2-1)) +1)<ε
Working on the second equation, I eventually got
|x|< (ε|x-1||x+1|)0.5
Suppose I restrict |x|<1
-1<x<1,
then
0<x+1<2 → |x+1|<2
-2<x-1<0 → 0<1-x<2 → |1-x|=|x-1|<2 (Is this step correct? In one of the textbooks, it says that we must always have x>0 which is important to conclude that for example, |x-1|<2 in the context of this question. Unfortunately, I don't see why we must conclude that x>0 because doesn't the modulus get rid of all negative values?)
So my choice for δ works out to be δ=min{1,2(ε)0.5}
However when I work backwards the problem arises.
Suppose I choose δ=1 → 2(ε)0.5 > 1 → ε>0.25
When I draw the graph, my δ-range of x=0 starts from the asymptote at x=-1 to the other asymptote x=1, and if this is the case, doesn't that mean the range ε about f(x)=-1 is infinite?
You have$$
\left |\frac 1 {x^2-1}+1\right |=\left | \frac {1+x^2-1}{x^2-1}\right |= \left |\frac{x^2}{x^2-1}\right |$$which you want to make small. The numerator will be small as ##x\to 0## but if ##x## gets anywhere near ##\pm 1##, that denominator will make the fraction large. So you must keep ##x## away from ##\pm 1##. That is easy since you have ##x\to 0##. So start by restricting ##|x|<\frac 1 2##. Figure out the smallest ##|x^2-1|## can be and overestimate ##\frac{x^2}{|x^2-1|}## by putting that smallest value in the denominator. Then you will be ready to figure out ##\delta## to make it all less than ##\epsilon##.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
