What is the equation for sine alpha when alpha is greater than 90 degrees?
  • Thread starter Thread starter fawk3s
    Alpha Sine
The discussion focuses on determining the equation for sine alpha when alpha exceeds 90 degrees. The original poster finds it straightforward for angles less than 90 degrees but struggles with the second triangle configuration. A participant suggests visualizing the problem by sliding the vertical line in the first triangle, which clarifies that sine remains the same while cosine and tangent become negative. This approach helps the original poster understand that the value of "a" becomes negative, leading to a clearer grasp of the concept. The conversation concludes with appreciation for the insight provided.
fawk3s
[PLAIN]http://img266.imageshack.us/img266/8206/triangles.png
This is not a homework question, but it is something I can't wrap my mind around.
What is the equation for sine alpha where alpha is greater than 90 degrees?
For the first triangle its easy: sine alpha = b/c
But what is it for the second triangle?
Thanks in advance,
fawk3s
Hi fawk3s! :smile:
(have an alpha: α :wink:)
hmm … why have you swapped a and b in the second diagram? :confused:
Go back to the first diagram, and just slide the vertical line (marked "b") to the left (dragging c with it), until the bottom line is length a again (but to the left) …
then b and c will be the same, and a will be minus the same, so sin is the same, and cos and tan are minus. :wink:
(it's easier to follow this if you draw a circle with the α angle at the centre and c as a radius)
Well, I think I follow. It seems quite easy and now when I think about it, it makes pretty good sense.
It didnt at first, I have to admit, since it seemed like you were finding the sin for the same angle as in the first diagram, but it all makes sense now because "a" is negative. Just too bad I didnt think of it myself :(
Thanks tiny-tim !
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
