Equation general of conic in polar coordinates
The discussion focuses on the conic equation in polar coordinates, highlighting the known parametric form, r = p/(1 + e cos(θ). Participants express curiosity about a general form of the conic equation in polar coordinates, noting that while it can be derived from the Cartesian version, it may appear complex. The conversation emphasizes that the parametric form is more suitable for polar coordinates, especially when the conic's center holds significance. There is a debate on whether seeking a general expression independent of Cartesian coordinates is necessary, with some suggesting that transformation is a natural approach. Ultimately, the complexity of deriving a general polar form is acknowledged, leaving the topic open for further exploration.
Jhenrique
The conic equation has 2 versions in cartesian coordinates:
The general: ##Ax^2 + Bxy + Cy^2 + Dx + Ey + F = 0##
And the parametric: ##y^2 = 2px + (e^2-1)x^2##
In polar coordinates, I known just the parametric: ##r = \frac{p}{1+e\cos(\theta)}##
But exist a general form too?
Mathematics news on Phys.org
You can express x and y in your general equation in terms of r and θ to get the general form. I think it will look quite messy. The parametric uses the "right" coordinate system, where the equation has a nice form. Usually there is no point in polar coordinates if the center does not have a special meaning.
But what you are suggesting is a transformation... I'm not looking for this, but yes by a general expression/format that is a conic but is independent of the cartesian format...
Well, you look for the result of a transformation. Isn't it natural to just do this transformation then?
Ahhh, does not matter... thanks of anyway
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
