Equation Help: Gravitationally Bound Rubble Pile Asteroid Orbit
  • Thread starter Thread starter higginsdj
    Orbit
The discussion focuses on calculating the minimum initial velocity required for surface material from a gravitationally bound rubble pile asteroid to achieve a circular orbit after reaching critical spin. It highlights that at critical spin, surface material travels at 2.28 m/s, while escape velocity is 3.28 m/s, emphasizing that escape velocity is not relevant for maintaining an orbit. The conversation also touches on the effects of gravitational force on detached objects, noting that they will experience a decrease in orbital velocity as they move away from the parent body. The importance of angular momentum in understanding these dynamics is acknowledged, with references to Newton's principles on projectile motion and orbiting. Overall, the thread provides insights into the complexities of orbital mechanics in the context of rubble pile asteroids.
higginsdj
Hi all,
I have a gravitationally bound rubble pile asteroid. This asteroid reaches and exceeds 'critical' spin where centripetal force exceeds gravitational force and surface material is launched off the surface.
At what minimum initial velocity would the surface material need to be to achieve a circular orbit? Just looking for the equation or a reference site.
Cheers
David
Astronomy news on Phys.org
Hi David! :smile:
As soon as it exceeds critical spin, any loose rock (on the top of the highest "mountain", say) will go into circular orbit (hopefully just missing the mountain on its return!).
(In practice, it'll collide will other rocks, and either crash, or get thrown out into some random elliptical orbit, where it will continue to collide with other rocks and eventually they'll all settle down to some regular pattern.)
I though this to, but then I might have confused myself. ie for my object, at Critical spin, the surface of the primary is traveling at 2.28 m/s. BUT escape velocity is 3.28 m/s. At the surface Fg = 0.00706 m/s^2. So when I spin fast enough for Fc = 0.00706, The surface object is traveling at 2.28 m/s and will effectively just be weightless on the surface where it is, higher velocities will actually launch it.
BUT, if the object is now disconnected from the parent, Fg will still be acting on it, the more distant the object gets from the parent the slower it's orbital velocity and thus like a projectile it should return to the surface so I am assuming this all has something to do with Angular Momentum BUT I am having trouble connecting all the dots.
Cheers
David
Hi David! :smile:
Escape velocity is irrelevant … it's the velocity for reaching infinity, not for orbiting.
A projectile doesn't have to return to the surface, it only has to keep falling.
As Isaac Newton pointed out, if you throw an apple hard enough horizontally, it will go into orbit … it keeps falling, but the Earth curves away beneath it fast enough to counter the falling.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
