How Do Equations for Tangent Planes Differ in Usage?
  • Thread starter Thread starter Calpalned
    Plane Tangent
Calpalned
What is the difference between the two given equations below? When would you use one or the either?
## z - z_1 = \frac{∂z}{∂x}(x_1, y_1, z_1)(x - x_1) + \frac{∂z}{∂y}(x_1, y_1, z_1)(y - y_1) ##
## \frac{∂f}{∂x}(x_0, y_0, z_0)(x - x_0) + \frac{∂f}{∂y}(x_0, y_0, z_0)(y - y_0) + \frac{∂f}{∂z}(x_0, y_0, z_0)(z - z_o) ##
I am confused because it seems like there are several equations for the tangent plane.
The two equations above are working with different forms for the equation of the surface on which you're asked to find a tangent plane.
In the first equation, you are given z as a function of x and y (i.e., z = g(x, y)).
In the second equation, the surface is given like this: f(x, y, z) = C.
thank you
You understand, I hope, that the second one is not an equation! I presume that was a typo and it was supposed to be equal to 0 or some other constant.
Given that, the first is generally used where you are given z as a function of x and y: z= z(x,y), with z_1= z(x_1, y_1).
The second would be used when you given some function of x, y, and z equal to a constant: F(x, y, z)= C.
That second form is more general since, if you have z= f(x, y), you can write it as F(x, y, z)= z- f(x, y)= 0 but if you are given F(x, y z)= C, you may not be able to solve for z. For example, F(x, y, z)= x^2+ y^2+ z^2= R^2[/itex] is the equation of a sphere. If you wanted to solve for z, you have to do two cases- z= \sqrt{R^2- x^2- y^2}['itex] and z= -\sqrt{R^2- x^2- y^2}.
