Equation of continuity of water depth
The problem involves a can filled with water, where a small hole at the bottom allows water to drain out. The objective is to find an expression for the time it takes for the can to empty, utilizing the continuity equation and principles from fluid dynamics, particularly Bernoulli's equation.
  • Participants discuss the application of Bernoulli's equation and the continuity equation to relate the outflow speed at the hole to the rate of change of water depth in the can. There are questions about the derivation of certain terms, such as the expression for the outflow speed and the relationship between the variables involved.
Some participants have provided insights into the use of Bernoulli's equation and its implications for the problem. There is an ongoing exploration of the relationships between the variables, with attempts to clarify the reasoning behind specific equations and terms. Multiple interpretations of the equations and their applications are being discussed.
Participants note the assumption that the area of the hole is much smaller than the cross-sectional area of the can, which influences the simplifications made in the equations. There is also mention of the need to consider the negative rate of change of height as the water drains.
etothey
A can of height h and cross-sectional Area Ao is initially full of water. A small hole of area A1<<Ao is cut in the bottom of the can. Find an expression for the time it takes all the water to drain from the Can. Hint: Call the water depth y use the continuity equation to relate dy/dt to the outflow sped at the hole and then integrate.
A1v1=A2v2
I tried to solve this by my own, managed to get stuck, and then tried to understand the solution from cramster. There they start mentioning the variables and one of the things they say is, Rate of change in volume through the orifice = A1V=s*(2gh)^1/2. This is the part i don't understand. Afterwards they set Ao*dh/dt equal to A1*(2gh)^1/2. I don't understand where (2gh)^1/2 comes from so that i can solve this.
Thankful for help!
hi etothey! :smile:
(have a square-root: √ and try using the X2 icon just above the Reply box :wink:)
it comes from Bernoulli's equation (conservation of energy) …
1/2 ρv2 = ρgh :wink:
You need to use Bernoulli's equation and the continuity equation to solve this problem. Applying the Bernoulli equation between the top of the fluid and the bottom of the can, we have
[tex]\frac{1}{2}\rho v_1^2 + \rho g y = \frac{1}{2}\rho v_2^2,[/tex]​
that is,
[tex]v_2^2 = v_1^2 + 2 g y.[/tex]​
But the continuity equation tells us that [tex]A_0 v_1 = A_1 v_2[/tex], so plugging into the Bernoulli equation, we have
[tex]v_2^2 = v_1^2 + 2 g y = \left(\frac{A_1}{A_0}\right)^2 v_2^2 + 2 g y[/tex]​
but they tell us that [tex]A_0[/tex] is much greater than [tex]A_1[/tex], so [tex]\left(\frac{A_1}{A_0}\right)^2 \approx 0[/tex], so we are left with
[tex]v_2^2 = 2 g y \Rightarrow v_2 = \sqrt{2 g y}.[/tex]​
Going back to the continuity equation, we have that
[tex]A_0 v_1 = A_1 v_2,[/tex]​
but we have seen that [tex]v_2 = \sqrt{2 g y}[/tex], and [tex]v_1[/tex] is the rate of change of the height as the fluid is drained, that is [tex]v_1 = - \frac{dy}{dt}[/tex] (notice the minus sign; [tex]v_1[/tex] is a positive function, but since the height [tex]y[/tex] is decreasing with time, its time derivative is negative, so we need to fix this by adding a minus sign). So, we have the following differential equation:
[tex]A_0 v_1 = A_1 v_2 \Rightarrow - A_0 \frac{dy}{dt} = A_1\sqrt{2 g y},[/tex]​
and you separate variables to find the time required for the can to fully drain.
Hope this helps.
tiny-tim said:
hi etothey! :smile:
sexy!
that is,
Hope this helps.
Thank you very much!
  • · Replies 19 ·
  • · Replies 24 ·
