Calculating Frequency for a Vertical Circle
  • Thread starter Thread starter fizixisannoying
    Frequency
To calculate the frequency for an object in a vertical circle, the relationship between tension, radius, and mass must be established. The proposed formula for frequency includes tension and weight, but it may not accurately apply to vertical motion as it does for horizontal motion. The tension in the string provides the necessary centripetal force, which is crucial for deriving the velocity equation. This velocity can then be related to frequency through the circumference of the circle. It's important to focus on understanding the concepts rather than simply seeking answers.
fizixisannoying
Someone help!
"Obtain an equation for the frequency in terms of tension, radius, and mass"
I'm having serious trouble with this question.
By the way...this is grade 12 physics...
I'm not sure if this is correct, but I came up with the formula frequency (f)= square root (tension+weight)/2pi*radius*sqareroot (mass). This would be the frequency expressed in terms of tension, radius, and mass at the top of a vertical circle, but I'm not sure whether this pertains to your situation or not.
this was for a horizontal circle...would the equation be the same?
btw, thank you!
Pete is evidently considering a verticle circle. For an ideal horizontal circle the situation is simpler (in ideal conditions, you don't consider the gravity pulling the string downward, and the length of the string can be considered to be equal tot he radius).
The tension in the string is what provides the Fc, so therefore the formula for Fc is manipulated to find a statement for v.
Then this result is equated to the basic equation for tangential speed (you know, circumference over period, or circumference times frequency).
BTW, Pete: hold back on simply giving out an answer. THis forum is for helping others, not just giving them answers. Good solution still (but for the wrong problem).
