Solve Equation Problem w/o Vieta: Find a^3+b^3+c^3
  • Thread starter Thread starter DoremiCSD
The discussion revolves around solving the equation 2x^3 - 15x^2 + 30x - 7 = 0 to find a^3 + b^3 + c^3 without using Vieta's formulas. The initial calculation yields a^3 + b^3 + c^3 = 754/8, but participants seek a method for the second part of the problem, which involves finding a new equation with roots 1/(a-3), 1/(b-3), and 1/(c-3). Some suggest using Euler's equation and manipulating the roots directly, while others express concern that this approach may inadvertently rely on Vieta's principles. Ultimately, the conversation emphasizes exploring alternative methods to derive the necessary coefficients without direct reliance on Vieta's formulas. The discussion highlights the challenge of adhering to the problem's constraints while seeking a solution.
DoremiCSD
If the equation 2x ^ 3 - 15X ^ 2 + 30 x - 7 = 0 has roots a, b ​​and c to find the value of the expression a ^ 3 + b ^ 3 + c ^ 3. Also to be found without using the types Vieta,the equation with roots 1 / (a-3), 1 / (b-3), 1 / (c-3)
I found the first part of a^3+b^3+c^3=754/8 but i can't find the second part of the exercise without using the type of vieta any ideas?
Wouldn't the equation be given by:
(x-r1)(x-r2)(x-r3) ?
yea but he (x-r1)(x-r2)(x-r3) conclude to the types of vietta.. he says to find the equation without to use vietta
What method did you use to determine this?
i used the types of vietta and i found abc,a+b+c,ab+bc+ca because its says to not use vietta types only in second statement and then i used eulers equation
a^3+b^3+c^3=3abc+(a+b+c)(a^2+b^2+c^2-ab-bc-ca)
So you as good as solved for the individual roots, then multiplied all 3 to get abc, and added all 3 to get a+b+c, etc?
yea as you know vietta is formed like this
abc=-d/a, a+b+c=-b/a, ab+bc+ca=c/a
So as you have determined 'a', can you now subtract 3 from that value of 'a' and take the reciprocal to get the new root r1, same for 'b' and 'c', and then multiply out (x-r1)(x-r2)(x-r3) ?
yea i understand but maybe this (x-r1)(x-r2)(x-r3) guide to vietta types? or not?
Is it permissible to work it out from basics, making no reliance on Mr Vieté's formulae? :smile:
Multiplying out (x-(a-3)⁻¹)·(x-(b-3)⁻¹)·(x-(c-3)⁻¹), collecting terms and setting the coefficient of x³ to unity, I can see that the coefficient of x² here can be obtained from the earlier equation as its coefficient of x plus 6 times its coefficient of x² plus a constant. The coefficient of x here can similarly be readily seen.
The difference from that earlier is that there is now no need to have actually solved for a,b, and c.
