Equation Questions for a gas powered engine driving a pulley system.
To calculate the horsepower needed for a gas-powered engine driving a pulley system to drag a 400 lbs. object up a 45-degree incline for 150 feet, the required force is 1322 Newtons, equivalent to 297.19 Pounds Force. The desired speed for this operation is 3 miles per hour, which converts to 4.4 feet per second. Using the formula for horsepower, the calculation yields approximately 2.38 horsepower needed for this task. Additionally, torque calculations may be necessary, depending on the pulley system's design and configuration. Understanding these variables is crucial for ensuring the system operates efficiently.
andywingett
I am building a prototype for an agricultural pulley system and I need help calculating how much horse power I need.
The pulley system will need to drag a 400 lbs. object of a 45 degree incline for 150 feet. The static coefficient of friction is 0.1 and the kinetic friction is only 0.05.
According to my calculations the Newtons of force needed to do this is 1322 = 297.19 Pounds Force.
I need to know how much horse power is needed to do this, and the amount of torque that will need to be exerted.
What are the other variables I need to input to solve this?
How fast do you want to drag the object up the incline?
Three Miles per hour.
Horsepower = P * V / 550
For your case, V = [3 mph * 5280 ft/mi] / 3600 s/hr = 4.4 ft/sec.
1 hp = 550 ft-lbs/sec.
P = 297.19 lbs
horsepower = 297.19 * 4.4 / 550 = 2.38 hp
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
