Equations for Accelerated Motion Problem 2
The discussion centers on a physics problem involving a car traveling at 60 mi/h that stops in 6 seconds. The user converted the speed to meters per second, calculated the acceleration as approximately 4.47 m/s², and determined the distance traveled to be 80.46 meters. A key correction was made regarding the initial and final velocities, emphasizing that the initial velocity is given and the final velocity is zero, which necessitates considering negative acceleration in the calculations. The final equation was confirmed to be correct with the appropriate adjustments for negative acceleration.
  • Understanding of kinematic equations in physics
  • Ability to convert units (e.g., miles per hour to meters per second)
  • Knowledge of acceleration as a vector quantity
  • Familiarity with the concept of initial and final velocities
  • Study the derivation and application of kinematic equations in physics
  • Learn about unit conversion techniques for speed and distance
  • Explore the implications of negative acceleration in motion problems
  • Practice solving similar problems involving initial and final velocities
Students studying physics, educators teaching kinematics, and anyone interested in solving motion-related problems in mechanics.
Medgirl314
A car traveling at 60 mi/h stops in 6 seconds. How far does it travel during this time?
a=Δv/Δt
x=xinitial+vinitialt+1/2(a)t^2
First I changed units into the standard ones:
60 mi/h *1609.34 m/1 mi * 1 h/3600 s = 26.8223 (the 3 seemed to be repeating.)
Then I used a=Δv/Δt, assuming the Vinitial was zero:
26.8223/6
a≈4.47 m/s^2
Finally, I plugged my numbers into this equation:
and got 80.46 m.
Would someone please check that this is correct?
a=Δv/Δt
26.8223/6
a≈4.47 m/s^2
and got 80.46 m.
That assumption isn't correct. The given velocity in the question is the initial velocity. And it stops after 6 seconds. Acceleration would be negative. And it seems you did take that into account in the final equation, otherwise the answer wouldn't be correct. Yes, the answer is correct. But be careful for the values you choose and assumptions you make, acceleration is negative anyhow in this case.
Edit: if you take ##a## to be positive, the final equation would have a minus sign.
##x=x_{initial}+v_{initial}.t-\frac{1}{2}.a.t^2##
Okay, thank you! I didn't take the negative acceleration into consideration at all, so thanks for pointing it out! I also used vintial twice when I meant to say one was vfinal. Oh! I got it backwards, the initial velocity was the given and the final velocity was zero. Thanks again!
  • · Replies 35 ·
  • · Replies 19 ·
