Equilibrim Physics Problems – Solve Now!
  • Thread starter Thread starter gnarrr
To achieve rotational equilibrium with a downward force of 40.5 N, the distance from point 'A' must be calculated using the equation T1 = T2 and F = 0. The initial attempt at solving the problem included incorrect calculations, leading to a distance of 6.18 m. It is essential to consider both clockwise and counterclockwise moments when calculating moments about the fulcrum. Proper sign conventions must be applied to ensure accurate results. The discussion emphasizes the importance of showing work and relevant equations when seeking help with physics problems.
gnarrr
http://img27.imageshack.us/img27/8011/physicsproblems.png
Hi gnarrr, welcome to PF.
Please go through the rules of the PF.
Don't post the problems alone. Show your attempts. List the relevant equations. Still if you don't get, we will help you.
The first one
Consider the bar to have negligible mass. How far from point 'A' must a downward force of 40.5 N be applied in order to achieve rotational equilibrium.
T1=T2
F=0
5x9.8x2.1 + 3.5x9.8x4.3 + 40.5xd = 0
d=6.18m
i figured out the second one
First on is wrong.
If you want to take the moment about the fulcrum, you have to consider clockwise and counterclockwise moments and use proper sings.
If you want to take the moments about A, 40.5 N and 3.5 kg produce clockwise moment and the reaction due to all the forces on the fulcrum will produce the counterclockwise moment. Equate them to get d.
