Equivalent Current Through Specific Resistor
The discussion focuses on calculating equivalent current through a specific resistor in a circuit. The user has determined the total resistance to be 5.22 ohms but is uncertain about calculating the current through a particular resistor. They note that with the voltage applied between points A and B, the current through the 1-ohm resistor can be derived. Additionally, they mention using the resistor divider formula to understand how current splits in a parallel resistor configuration. The conversation emphasizes applying Ohm's law and the principles of current division in parallel circuits.
ScienceGuy787
http://farm5.static.flickr.com/4117/4775531139_8d4dd954f5_b.jpg
I = V/R
E = I1R2 = I2R2 =I3R3
I got 5.22 ohms for part (a), but I'm not sure how to go about calculating the amps through a specific resistor.
part b is simple. You have calculated the total resistance of the circuit. So given the voltage applied between A & B, you could calculate the current, & this much of current has to pass through the 1 ohm resistor.
for part c, do you know how current splits into each branch in a parallel resistor combination ?
thats simple..use resistor divider formula..
