Error Propogation - E of Gravity due to r
  • Thread starter Thread starter skateza
    Error Gravity
The discussion focuses on deriving an algebraic expression for the error in gravity (Eg) due to uncertainty in the radius (r), while assuming no errors in G and M. The equation for gravitational acceleration is given as g = (GM)/r^2. Participants explore the relationship between changes in r and g, emphasizing the need to avoid calculus in favor of algebraic methods. The conversation highlights the use of binomial expansions to approximate changes in g due to small changes in r. Ultimately, the goal is to express the error in gravity without resorting to derivatives.
skateza
The acceleration due to gravity is given by Newton's universal law of gravitation as:
g=(GM)/r^2
Derive an algebraic expression for the error in gravity (Eg) due to the uncertainty in r. You may assume that the errors in G & M = 0; (EG & EM = 0)
Let E=error in for internet purposes
g=(GM)/r^2
r^2=(GM)/g
r=(GM/g)^(1/2)
r=[(GM)^(1/2)]/[g^1/2]
This is calculus, i can't see a classical algebraic way of doing this..
any help please?
Suppose f is a function of r. Then:
f + \delta f \approx f(r) + \delta r f^{\prime}(r)
so \delta f \approx \delta r f^{\prime}(r)
Can you see why this is the case?
in the second half of that you are taking the derivative of the function, as far as i am convinced this course is an algebra based course and I'm trying to figure out an algebraic response to this question, without taking the derivative at any point... would it be
r^2+Er^2=GM/g+Eg
Okay, then:
g + \delta g = \frac{GM}{(r + \delta r)^2}
Knowing that g = \frac{GM}{r^2}
Apply binomial expansions as necessary.
