Escape velocity for object on Earth
3 replies · 4K views · last reply
thyrgle
Suppose the gravitational force of the Earth on a body was [itex]F = \frac{KMm}{r^3}[/itex]. What escape velocity would a body need to escape the gravitational field of the Earth?
[itex]v_e = \sqrt{\frac{2GM}{R}}[/itex]
[itex]F_g = G*\frac{m_1*m_2}{r^2}[/itex]
[itex]G*\frac{m_1*m_2}{r^2}=\frac{KM_em}{r^3}[/itex]
m_1 and m_2 cross out with M and m. r^3 and r^2 can be reduced to give:
[itex]G=K/R[/itex]
Re-plug back into v_e equation:
[itex]\sqrt{\frac{2KM}{R^2}}[/itex]
But the given solution says:
[itex]\sqrt{\frac{KM}{R^2}}[/itex]
Where did I go wrong? Thanks!
No, you're misunderstanding the problem. You shouldn't use Newton's Universal Law of Graviation, because the whole point of the problem is to ask, "what if we lived in a universe where Newton's universal law of gravitation was different and was an inverse-cube law instead of an inverse-square law?"
Hint: for a conservative force, we have:[tex]F = -\frac{dU}{dr}[/tex]which means that[tex]U = -\int F(r)\,dr[/tex]where this integral will give you an arbitrary constant, but we have the freedom to set this arbitrary constant to whatever we want, and we typically set it to 0 so that the potential energy goes to 0 at infinity.
Ok thank you!
I can take the integral of (KMm/r^3) and get:
[itex]\frac{KMm}{2r^2}[/itex]
then:
[itex]\frac{1}{2}mv^2 - \frac{KMm}{2r^2} = \frac{-KMm}{r_{max}}[/itex]
[itex]v^2 = 2KMm\times (\frac{1}{2Rr^2})[/itex]
[itex]v = \sqrt{\frac{KM}{R^2}}[/itex]
Thanks again!
thyrgle said:
Ok thank you!
then:
Thanks again!
I don't understand your second equation, particularly the KmM/r_max term. All you have to do is equate the potential energy to the kinetic energy. (1/2)mv^2 = KMm/(2r^2). This gives you the right answer.
