Escape Velocity of Heated Nitrogen: A Scientific Inquiry
The escape velocity of nitrogen heated to 325 K is a concept that aligns with the general definition of escape velocity, which does not depend on temperature. Instead, the focus should be on the mean velocity of the gas, which can be influenced by temperature. The kinetic theory of gases indicates that nitrogen, being diatomic, has additional degrees of freedom affecting its energy distribution. The Maxwell-Boltzmann distribution describes the range of molecular speeds at a given temperature. Understanding these principles is crucial for analyzing gas behavior in relation to escape velocity.
willstaruss22
What is the escape velocity of nitrogen heated to 325 K?
Same as the escape velocity for anything.
http://en.wikipedia.org/wiki/Escape_velocity
What you are usually interested in is if the mean velocity of the gas at some temperature is greater than the escape velocity ... in which case you need the relationship between mean velocity and temperature.
aside:
"the escape velocity of the Earth" would be the minimum speed you need to escape the Earth's gravitational field from it's surface.
"the escape velocity of Nitrogen" would be the minimum speed you need to escape a Nitrogen (atom? molecule?)'s gravitational field from it's surface.
But I'm guessing that is not what you mean :)
Yes i meant the escape velocity from the surface if molecular nitrogen was heated to 325 K. I would imagine it would be faster because the colder the temperature the lower the escape velocity.
Again - the escape velocity does not depend on temperature.
You want to look into the kinetic theory of gasses:
http://hyperphysics.phy-astr.gsu.edu/hbase/kinetic/kintem.html
... since Nitrogen is diatomic, there's an extra two degrees of freedom so:KE_{avg}=\frac{5}{2}kT [edit: incorrect - that's all energy ... must be half asleep!]
... a gas at a particular temperature will have a range of speeds - given by the Maxwel-Boltzman distribution.
The energy corresponding to rotation does not influence the escape, however. It is kinetic, but it does not change the speed of the molecule.
@willstaruss22: I think it would be more useful if you ask all questions about the atmosphere in a single topic.
I'd have though that energy going into the rotation would be energy not available for translation?
[edit] Oh wait - I see where I stuffed up <sheepish>
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
