Calculating Steam Needed to Heat Espresso from 50C to 80C
  • Thread starter Thread starter Physics321
To calculate the steam needed to heat a 20 cm^3 cup of espresso from 50°C to 80°C, the user correctly identifies the mass of the espresso as 20 g. They set up the energy balance equation but are struggling with the calculations, particularly the energy contributions from steam condensation and temperature change. Despite following the right approach, the homework software indicates their answer is incorrect, prompting a request for urgent help. Forum members suggest providing the final answer to identify the mistake and advise against frequent thread bumps due to varying time zones. Accurate calculations and clarity in the setup are crucial for resolving the issue.
Physics321
I am having trouble with this question:
The temperature of the espresso coffee (mostly water) can be increased by blowing 100 C steam into it. How much steam (in grams) is needed to heat up a 20 cm^3 cup of espresso from 50 C to 80 C? What is the volume of this quantity of steam assuming that the steam is an ideal gas?
So far I have started like so:
Since the 20 cm^3 conversion to grams with water is just 1:1 I just said 20 g of water for starting.
And approached it like so:
(20g)(1 g/cal)(80 C – 50 C)= -ms(-540 cal/g) + (1 cal/g)(80 C – 100 C) and got ms to be roughly 1.11 g of steam.
Don't know the numbers for cal off by heart but that's the right approach
mass coffee * specific heat cap * temp change = energy (steam->water) + mass steam * specific heat cap water * temp change (from 100 to final T)
my approach is
mass of coffee*specific heat of water(1cal/g/K)*delta T= mass of steam * heat of condensation(540cal/g)+mass of steam * 1cal/g/K* (100-final T)
and the homework software determined that I am wrong
HELP! due tomorrow 10 am
help!
anyone?
1989.1989 said:
my approach is
It may be too late to help you, but here is some advice for the future:
Show what answer you got. You have set up the correct equation, so we can't tell where your mistake is.
This forum has people from all over the world, from many different time zones. We don't know when "10 am" is for you.
Don't bump your thread every couple of hours.
