Estimate global temperature increase from solar forcing
The discussion focuses on estimating the contribution of solar forcing to the global temperature increase since 1900, using a climate sensitivity of 0.5K per watt per square meter. Calculations indicate that solar forcing could account for an increase between 0.03°C and 0.12°C based on values ranging from 0.06 to 0.24 w/m2. Participants express uncertainty about whether to present the results in absolute terms or as a percentage. The importance of including units in the final answer is emphasized. Overall, the calculations suggest that solar forcing has a relatively minor role in the observed temperature rise.
nwag93
using a climate sensitivity of 0.5K per watt per square meter, estimate how much of the .9 c global temperature increase since 1900 could be due to solar forcing who value is the range of .06 to .24 w/m2
.5 x .06 = .03
.5 x .24 = .12
Im not sure If I am on the right track
Yes, I believe that's all that's needed, but always include units. Maybe you are expected to represent the answer as a percentage?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
