Evaluate INT (5+cosx)e^-x from 0 to infinity
  • Thread starter Thread starter IntegrateMe
    Infinity
IntegrateMe
ok so i got (5+cos x)/ex and i compared that with 1/ex
(they're both going from 0 to infinity).
Turns out that the integral of 1/ex from 0 to infinity converges to 1. But i don't know how to prove that our original function converges as well (which is the answer). Anyone care to help?
Split the integral into: 5\int_0^\infty{e^{-x}}dx+\int_0^\infty{cosxe^{-x}}dx
and since you know the first one is equal to 5, just use integration by parts to find the second and then add 5 to it.
You could also compare your original integral with 6/e^x. Which is larger?
If you're just trying to prove that the integral converges, the fact that \int_0^{\infty}\exp{(-x)}\mathrm{d}x converges is enough to prove that the second integral in Mentallic's post converges. For example, |\cos{(x)}| \leq 1 from which it follows that \exp{(-x)}|\cos{(x)}| = |\exp{(-x)}\cos{(x)}| \leq \exp{(-x)} and then using this inequality we can reduce the convergence of the second integral to mere trivialities. However, if you actually need to evaluate the integral, Mentallic's method is definitely the best way to go.
Edit: I would follow Dick's advice since his suggestion is considerably simpler than mine.
Nah, it's not that much simpler. Mine only works because (5+cos(x)) is nonnegative. If it were (1+cos(x)) IntegrateMe would definitely want to use your comparison.
First break the integrand into twp parts as shown by Mentallic.You can reduce the pain of integration by writing cos(x) as Re[exp(ix)];next solve the integration,which is now trivial.Then,take the real part of the resulting indefinite integral and put the limits.The lower limit gives you finite value and the upper limit gives you zero for the e^-x factor.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
