Evaluate Limit with L'Hôpital's Rule: x => 0 of sqrt(x^2+x) - x
  • Thread starter Thread starter nothing123
    L'hopital's rule
nothing123
evaluate the limit as x=>0 of sqrt(x^2+x) - x
so i multiplied by the conjugate to get:
x^2 + x - x^2 / sqrt(x^2 +x) + x
which simplifies to:
x / sqrt (x^2 + x) + x = infinity/infinity
taking LH, you get:
1 / 1/2(x^2+x)^(-1/2) * (2x+1) + 1 = infinity/infinity again
looking ahead, it doesn't look like LH is going to help
any suggestions?
Are you sure it's not infinity?
Suppose you mean:
\lim_{x \rightarrow \infty} \sqrt{x ^ 2 + x} - x
If x \rightarrow - \infty, you will have: \infty + \infty = \infty, the limit does not exist for that case, so here, we are going to find the limit of that expression as x tends to positive infinity.
\lim_{x \rightarrow + \infty} \sqrt{x ^ 2 + x} - x
This is good.
Do you need to use L'Hospital rule? If not, you can consider dividing both numerator, and denominator by x to get:
\lim_{x \rightarrow + \infty} \sqrt{x ^ 2 + x} - x = \lim_{x \rightarrow + \infty} \frac{x}{\sqrt{x ^ 2 + x} + x}= \lim_{x \rightarrow + \infty} \frac{\frac{x}{x}}{\frac{\sqrt{x ^ 2 + x} + x}{x}}
= \lim_{x \rightarrow + \infty} \frac{1}{\sqrt{1 + \frac{1}{x}} + 1}, (since x is positive (x \rightarrow + \infty), so \sqrt{x ^ 2} = x)
Can you go from here? :)
Well, in this case you don't need to multiply by the conjugate because if you just evaluate this function with x being 0 you get 0. This function is continuous in x = 0 so you can just calculate the limit of f(x) by calculating f(0).
marlon
sorry to cut into this post but I am working atm on a question similar to this, i haven't even seen LH rule in my book so that may be why I am going to ask this question
how did you turn all those x's into 1's and 1/x in the numerator?
Standard step you should have learned as the first thing in limits: if you are taking limits as x goes to infinity, divide numerator and denominator by the highest power of x. That way all the "x"s become "1/x"s and instead of going to infinity, they go to 0.
yep that makes sense, thanks
VietDao, based on your calculations, I get 1/2 as an answer. However, I don't know how your supposed to divide sqrt (x^2 + x) by x. Doesn't this violate BEDMAS rules b/c I thought sqrt(x^2+x) does not equal sqrt(x^2) + sqrt(x).
What are BEDMAS rules??
sorry nvm, i forgot that sqrt(a) divide sqrt(b) = sqrt(a/b). thanks for everyones help.
