Evaluate the definite integral
The discussion revolves around evaluating the definite integral of the function \( \int^{a}_{0} x\sqrt{x^{2}+a^{2}} \) where \( a > 0 \). Participants are exploring integration techniques and substitutions relevant to this problem.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of substitution \( u = x^{2} + a^{2} \) and the implications of omitting \( dx \). There are attempts to evaluate the integral using different approaches, and some participants express confusion about the notation and mathematical expressions used.
The discussion is ongoing with various interpretations being explored. Some participants have provided hints and partial evaluations, while others question the clarity and correctness of the mathematical expressions presented. There is no explicit consensus on the final evaluation of the integral.
Participants are working under the assumption that \( a \) is a positive real number, and there is some confusion regarding the assignment of specific values to \( a \) during the evaluation process.
frosty8688
1. [itex]\int^{a}_{0} x\sqrt{x^{2}+a^{2}}[/itex] a > 0
2. u = x[itex]^{2}[/itex] + a[itex]^{2}[/itex], du = 2x
3. [itex]\frac{1}{2}\int^{a}_{0}\frac{2u^{3/2}}{3} = \frac{1}{3}\int ^{a}_{0}(x^{2}+a^{2})^{3/2}[/itex] How do I solve this? Any hints?
You have omitted dx. You might think this to be an unimportant appendage that can be ignored, but as you learn additional integration techniques, it becomes very important.
In your ordinary substitution, u = x2 + a2, and du = 2xdx[/color].
Making the substitution, you get
$$ \frac{1}{2}\int_0^a u^{1/2}du = \frac{2}{2 \cdot 3}\left. u^{3/2} \right|_0^a$$
$$ =\frac{1}{3} \left. (\sqrt{x^2 + a^2})^3 \right|_0^a$$
Evaluate the quantity at x = a, and then at x = 0, and subtract the two values.
So we let a = 1 and 1+1 = 2 and it would be sqrt 2^3 which would be 2 sqrt 2 - (0+1)^3 = 1 all to a^3 * 1/3.
No, you don't assign a value to a.
Instead of writing stuff like "which would be 2 sqrt 2 - (0+1)^3 = 1 all to a^3 * 1/3" that makes little sense, try writing some actual mathematics, with = between equal expressions.
So [itex]\left|x\right| = a[/itex] and -a.
Is there an equation I can use to compute the values of x?
I got it when a is evaluated x = +/- 1 and since x=a +/- 1^2 + +/- 1^2 = 2 and when the lower limit is evaluated x = 0, but a > 0 so that makes the expression equal to 1.
"a" is simply "a", an arbitrary positive real number. Your answer should have "a" in it.
I have [itex]\frac{1}{3}(2\sqrt{2}-1)a^{3}[/itex]
Looks good.
  • · Replies 105 ·
13K
  • · Replies 22 ·
  • · Replies 19 ·
