Evaluate the integral inside domain V, where V is bounded by the planes
The problem involves evaluating a triple integral of the form ∫VxdV over a specific domain V, which is defined by the planes x=0, y=x, z=0, and the surface x²+y²+z²=1. The discussion centers around the challenges of setting up the integral correctly and the appropriate coordinate system to use.
  • Participants discuss the setup of the triple integral and the limits of integration, with some suggesting the use of spherical coordinates for simplification. There are questions about the correct bounds for y and z in relation to the defined surfaces.
There is ongoing exploration of different approaches, including Cartesian and spherical coordinates. Some participants express confusion over the limits of integration and the interpretation of the bounded area, indicating that the original problem may have ambiguities. No consensus has been reached regarding the correctness of the answer key.
Participants note that the projection of the surface in the xy-plane leads to a quarter circle, and there is a discussion about the correct interpretation of the bounds, particularly regarding the range of y. The original poster's calculations are questioned, and there is a suggestion that the answer key may be incorrect.
Cloudless
1. Evaluate the integral
VxdV
inside domain V, where V is bounded by the planes x=0, y=x, z=0, and the surface x2+y2+z2=1
Answer given: 1/8 - √2/16 (which is NOT what I got.. )
2. The attempt at a solution
Ok, it's a triple integral, I know this.
∫dx runs from 0 to 1
∫dy runs from -√1-x2 to x
∫dz runs from 0 to √1-x2-y2
So the order of integrals go ∫∫∫dz dy dx
Yeah... it's not working. I keep getting stuck with things like x(1-y2-x2)1/2 which I can't integrate onwards... :cry:
Hi Cloudless! :smile:
Cloudless said:
VxdV
this is a vertically sliced wedge from θ = 45° to 90°, so it would be much easier to use spherical coordinates :wink:
of course, you can use x y z, but …
no
no
In the xy-plane, z= 0 so [itex]x^2+ y^2+ z^2= 1[/itex] projects to the quarter circle [itex]x^2+ y^2= 1[/itex]. For each x, y ranges for 0 up to [itex]y= \sqrt{1- x^2}[/itex], NOT [itex]y= -\sqrt{1- x^2}[/itex] because the bounding surface is above the xy-plane.
I redid it in spherical coordinates. Much easier, but still missing a pi/2. I think the conclusion is the answer key was wrong.
The question was ambiguous in its bounded area. I thought it was from negative pi/2 to pi/4.
If you want us to check your answer, you'll have to show us your calculations. :wink:
