Evaluating integral in terms of Gamma functions
arex
The Gamma function is given by \Gamma(x) = 0 tx-1e-t dt
Evaluate 0 exp(-αy2)dy in terms of Gamma functions.
n/a
Honestly, I don't know where to start. I have knowledge of parametric differentiation (we use alpha as the variable in class which may hint at its usage here) but I don't immediately see how it would help or what it even means to evaluate the integral "in terms of gamma functions."
I'm not just looking for the answer, I'd like a starting hint or tip to get going.
n/a
You obviously need to find some alternative expression for the Gamma function that involves an integration with exp(-y^2) in it.
RGV
RGV
I think arex can work with that definition. Try the change of variable x=ay^2.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
