Evalute the following integrals
  • Thread starter Thread starter manal950
    Integrals
manal950
Hi
Evalute the following integers
You mean "integrals". There's a HUGE difference between integers and integrals!
Plus, where's the problem you're facing with these qns and your attempts?
Remember to change your integration limits after the substitution!
Hi
all is correct instead of substitution ??
manal950 said:
Hi
Your substitution is fine.
What is u when \ x=\sqrt{\ln(\pi)}\,,\ and when x = 0. Those are your limits for the integral in u .
Otherwise, use substitution to find the anti-derivative in terms of u, then convert that anti-derivative back to x and evaluate the definite integral using the limits for x.
thanks so much ...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
