Exact Differential Equations and Integrating Factor
Color_of_Cyan
"Show that each of the given differential equations of the form M(x,y)dx + N(x,y)dy = 0 are
exact, and then find their general solution using integrating factors μ(x) = e∫h(x)dx and μ(x) = e∫g(y)dy
(x2 + y2 + x)dx + (xy)dy = 0
Can someone please tell me how to get started or what to do after? This is very confusing for me. I did THIS EXACT SAME problem before but in another way, where it said to show exactness and I had to use the integrating factor to show exactness and THEN solve using grouping. NOW it's saying to use integrating factor to find the general solution itself. I don't get it, this is very confusing to me. The ANSWER for the general solution ends up to be 3x4 + 6x2y2 + 4x3 = C... Anyways:
M(x,y) = ( x2 + y2 + x ) ; N(x,y) = xy
h(x) = [ ( dM / dy ) - ( dN / dx ) ] / N ;
integrating factor = e∫h(x)dx
h(x) = (2y - y) / xy = y/xy = 1/x ; h(x) = 1/x
integrating factor = e∫(1/x)
integrating factor = eln x ; integrating factor = x
Now what do I do with it? Am I to just solve using 'grouping' or solve using 'brute force' method? Or do I take integrating factor again except using N(x,y) and then what? This is really getting me mad.
I'm also confused. Are you sure you're supposed to show (x^2 + y^2 + x)dx + (xy)dy = 0 is exact? But it's not. The whole point of using integrating factors is to make a non-exact equation exact.
That's my point :/
Should I just go ask my instructor?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
