Exact solutions and the convergence of eulers method
  • Thread starter Thread starter thedude36
    Convergence Method
thedude36
im having trouble with this question - http://i.imgur.com/Ars4J1b.png - more specifically with part a, as i have a good idea how to go about b. given the initial value problem
y' = 1-t+y , y(t0)=y0
show that the exact solution is
y=\phi(t)=(y0-t0)et-t0+t​
we've only spoken of approximations in class and I've just been kind of guessing as to how i should go about it so far. I've tried to look up the term exact solutions but haven't found anything of much use.
integrating factor: if dy/dt+ay=g(t), then μ(t) is such that dμ(t)/dt=aμ(t). Multiply both sides of the equation dy/dt+ay=g(t) by μ(t) to obtain μ(t)dy/dt+ayμ(t)=μ(t)g(t).
rearranging the given formula, i was able to get
dy/dt-y=1-t​
where a = -1. thus, dμ(t)/dt=-μ(t) making μ(t)=e-t. multiplying bothsides give
e-tdy/dt-e-ty=e-t-te-t
the left side can be obtained by the power-rule if the initial function was d(ye-t)/dt so we replace the leftside with this
d(ye-t)/dt=e-t-te-t
integrating bothsides and then solving for y gives
y=-2-t+cet
however, i don't think this is the correct method. What should i be doing instead of this?
Your method is fine. You just have a mistake calculating your last line. Re-check that -2-t.
Thanks! I am not sure how i was integrating that wrong, but a quick check on a calculator quickly resolved the issue. I appreciate it!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
