Existence oF Fourier Co-efficient
  • Thread starter Thread starter Sultan Ahmed
    Existence Fourier
Sultan Ahmed
Let f(t) be a signal whose time period is T.
1. if f(t+T/2)=f(t) proof that the Fourier series representation will contain no odd harmonics
2. if f(t+T/2)=-f(t) proof that the Fourier series representation will contain no even harmonics
1. I tried to proof that for f(t+T/2)=f(t) odd Fourier co-efficient is zero . But I can not prove that .
You should write down the definition of the Fourier series coefficients. Then take a good look at them and try to argue that they are 0 for odd numbers, given that f(t+T/2)=f(t). If you can't figure it out: what is the definition of the coefficients?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
