Existence of limit of a function with a parameter
AwesomeTrains
For what values of a, from the reals, does the limit exist?
lim_{x\rightarrow2} (\frac{1}{2-x}-\frac{a}{4-x^{2}})
I chose a so that the denominator would be one. By putting the fractions together.
When a = 4 the denominator of the combined fraction can be reduced to one
=> then the limit is -1/4.
(For a=x+2 and a=x^{2}+x-2 the denominator is 1 too, but at x=2 all three solutions are equal to 4.)
\textbf{tl;dr}
\textbf{My question: Is 4 the only solution?}
In the problem statement a is in plural.
Am I missing any solutions?
Any hints are much appreciated.
\textbf{tl;dr}
You have the correct answer. To see that there are no other answers, add the two fractions together and see if you can argue that having a finite limit implies a = 4.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
