Exothermic Reaction Origin: What is the Source?
  • Thread starter Thread starter Farside
    Exothermic Origin
The origin of energy liberated in an exothermic reaction is primarily due to the potential energy stored in molecular bonds. In these reactions, more bonds are formed than broken, resulting in a net release of energy. Bond-making processes are exothermic, contrasting with bond-breaking, which requires energy input. A practical example is the dissolution of sulfuric acid in water, where the reaction releases significant heat due to the formation of stronger bonds in the aqueous solution, indicating a more stable state. In biological systems, the cleavage of phosphorus-oxygen bonds in molecules like ATP releases substantial energy, highlighting the role of exothermic reactions in energy transfer and storage.
Farside
what is the origin of the engery liberated in an exothermic reaction? I've been hitting the books for this but can't find it. Seems simple enough though. I just need to be sure.
Chemistry news on Phys.org
Its a form of potential energy that is stored in the bonds of a molecule.. Think of a mouse trap.
Bond making is an exothermic reaction (opposite of bond breaking in which energy must be applied to break the bonds). If there is a reaction in which more bonds are made than bonds broken than it is an exothermic reaction. The reaction in which weak bonds are broken and strong bonds are formed is also an exothermic reaction.
Hope this helps.
Ab S.
I'll give an example, maybe this will clarify something.
Sulfuric acid dissolves in water with evolution of great amounts of heat. In here, as DeathKnight and so-crates said, some bonds are broken and their energies are evolved as unused energy. This can be explained in another point of view, sulfuric acid dissolved in water has a lower energy, thus more stable than its non-aqueous counterpart. This results with an energy flow outside, what we call as "exothermic" reaction.
In biological sytems, phosphorus-oxygen bond cleavages, as in ATP and ADP, etc., are used frequently, since it gives great energy gain. Adenosine triphosphate can be regarded as an "energy bank", which releases energy upon "application".
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
