I Is Something Missing in the Expansion of Our Flat Universe?
The discussion centers on the implications of the Friedmann equations for a flat universe, specifically addressing the conditions under which the universe can be considered flat (k=0) and the relationship with critical density (ρ=ρc). Participants clarify that while k=0 is theoretically possible, it is practically a null set due to measurement limitations. The conversation explores whether a universe with k=±1 can exist simultaneously with critical density, concluding that it cannot, as this would necessitate k=0. The thread emphasizes the importance of understanding the mathematical relationships in cosmology to avoid misconceptions about universe expansion and curvature. Ultimately, the discussion reinforces that k and ρ are intrinsically linked in defining the universe's geometry and expansion behavior.
Apashanka
From friedmann equation
And
For a flat universe with k=0 and ρ=ρc ,da/dt becomes undefined and d2a/dt2 becomes 0
But for the present time we know that our universe is flat and expanding with a acceleration (q -ve) ,
Therefore is it here something I am missing??
Space news on Phys.org
Hi,
Precisely ## k ## refers to the spatial curvature of our Universe. Actually ## k \neq 0 ## but It is really close to ##0##.
\begin{cases}
k > 0 \quad \text{closed "spherical" universe} \\
k = 0 \quad \text{flat universe} \\
k < 0 \quad \text{open "hyperbolic" universe}
\end{cases}
The set of Universe with ## k = 0## is a ##\textbf{null set}##, then the probability of having such Universes is equal to zero. It is not experimentally meaningful to find ##k## precisely ##0##, there is always an error bar.
Usually in Friedman equation you can neglect the spatial curvature, but it does not mean that it is precisely ##0##
Where are you getting this from?
addaF said:
The set of Universe with k=0 k = 0 is a null set\textbf{null set}, then the probability of having such Universes is equal to zero.
This is true as a matter of actual measurements (we can never measure ##k## to be exactly 0), but irrelevant to the question the OP is asking, because he is claiming that a theoretical model with ##k = 0## is somehow inconsistent. That can be shown to be wrong without considering the measurement aspect at all.
addaF said:
is a null setnull set\textbf{null set}, then the probability of having such Universes is equal to zero
This is not necessarily true. It is only true if you assume that the probability distribution for k is everywhere finite. It is perfectly fine in probability theory to have probability distributions where the cdf is not continuous, ie, with particular points having a non-zero probability. The set k=0 is null in the standard measure on the real numbers, but that in itself means very little.
Sorry I am not in a position to text right now ,I am reposting my question
My response is still the same: where are you getting this from?
From the first Einstein field equation for FRW metric
3H2+3k/a2=8πGρ,little simplification gives the result posted in #6
Where ρc is 3H2/8πG(critical density)
(From R00-1/2Rg00)=8πGT00
Have you considered the possibility that what your "little simplification" implies is not that ##\dot{a} = \infty## for ##\rho = \rho_c## and ##k = \pm 1##, but that ##k = \pm 1## is not possible if ##\rho = \rho_c##?
So why is the word 'HALT EXPANSION AFTER INFINITE TIME ' is associated with critical density ??
Is it something related to this
The first one for expansion with acceleration and the second one with linear expansion .
Implies after the time at which ρ=ρc , a is not defined ,is it so??
(It is only for k=+-1,k=0 will allow expansion forever)
Please give a specific reference where you are getting all this from. We can't comment on vague statements with no source.
I've already given you a strong hint in post #9. You need to go back and re-check the math. It doesn't mean what you think it means.
Apashanka said:
This gives no math other than the definition of ##\rho_c##. Can you show me a source that says "just halt its expansion but only after an infinite time" and gives the math that supports that? "Source" means "textbook or peer-reviewed paper"; you need to be looking at those to get a proper understanding of this issue.
(Hint: if you find such a source, you will find that the math it gives only allows ##k = 0## if ##\rho = \rho_c##.)
Is it that for k=+-1 ,at the time of ρ=ρc ,a(t) at that time can't be defined ,that's why it is not allowed ??
But for k=0 ,it will allow expansion or contraction (linear or accelerated) forever...
As you have been told repeatedly, you cannot have ##\rho = \rho_c## without having ##k= 0## or vice versa. The curvature is directly dependent on the energy content relative to the expansion rate.
There is no such thing as ”the time of ##\rho = \rho_c##”. It is either satisfied at all times or it is never satisfied.
Orodruin said:
There is no such thing as ”the time of ρ=ρcρ=ρc\rho = \rho_c”. It is either satisfied at all times or it is never satisfied.
Ok if ρ=ρc is satisfied for all times , then for k=+-1 , the scale factor can't be defined...and no question of expansion or contraction or static.
Is it??
Is it??
Really? You are not reading. Reread the statement. You cannot have ##k = \pm 1## when ##\rho = \rho_c## because then ##k = 0## by definition.
The OP question has been answered. Thread closed.
