Expectation of a function of X and Y
gjones89
Find E[X^Y], where X and Y are independent random variables which are uniform on [0,1].
I know that to get E[f(x)] for a function of one continuous random variable X, you integrate xf(x) between minus and plus infinity.
I tried to generalise this method for a function of two variables and integrate [x*y*f(x,y)] as a double integral for x and y between 0 and 1. So I have a double integral with [x*y*f(x,y) = (x^(y+1))*y] under the integral signs. When I solved this as a double integral (integrating with respect to y first), I ended up with an answer of 2ln(2/3) + 1. Am I using the right method?
This is incorrect. Suppose that X is a random variable, uniform on [0,1], with pdf f_X. Then the expectation value of a function g(X) is
E(g(X)) = \int_0^1 dx~g(x) f_X(x).
There's no factor of x inserted.
No, if you use the correct formula above,
E(X^Y) = \int_0^1 dx \int_0^1 dy~ x^y f_X(x) f_Y(y).
Since x,y are uniform, f_X=f_Y=1. The answer will still have a logarithm in it.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
