Expectation value for Hydrogen radius
physgirl
Find the expectation value for a hydrogen atom's radius if n=25 and l=0.
expectation value = <f|o|f>
where f=wavefunction and o=operator
So I know that to find an expectation value, you integrate over all relevant space: (f*)(o)(f)...
However I'm not sure what "f" is in this case... my book only lists hydrogen atom wavefunctions up through like n=3, but nothing past it... also what would be the operator that relates to radius??
In class I think we derived something for the H atom that shows that its wavelength has a radial and an angular part but I'm entirely confused :frown:
Also, what's the difference when the question is stated like above and when it says to find the mean radius <r> of H in a certain orbital? Isn't it pretty much the same thing?
Find a table of Generalized Laguerre polynomials. Can't imagine you'd be expected to integrate 26 terms though! :confused:
The operator you want is the position operator.
Do you mean "wavefunction"?
Pretty much.
Are you sure l = 0. It's much more common to take, for large n, l = n - 1, as this corresponds (for each n) to the only circular orbit in Bohr-Sommerfeld theory, and the polynomial in r then only has one term.
If it really is l = 0, then I'd use a compute package like Maple or Mathematica.
A recursion relation [Eq. (13.33) in Arfken's 2nd editon], let's you replace
r(L_n)^2 by (2n+1)(L_n)^2 in the integral for <r>.
Oh, oops, Gokul, I did mean wavefunction, not wavelength...
And yes, my question does state l=0...
Meir Achuz- can you explain a bit more? I'm not sure what you're talking about :(
Also, what is the use of the equation:
L" + (2l+2 - rho)L' + (n - l+1)L = 0
You are on the right track
You should probably find another textbook, which gives a general form of wavefunctions \psi_{n,l=0,m=0} (r) for all n.
In the position representation this is just multiplication by r.
You don't need to worry about the angular part, because for l=0 there is no angular dependence.
Yes, it is the same thing.
Eugene.
Eugene, I think I found the general form of wavefunctions that you're referring to, but it had a summation term which expanded from j=0 to j=n-l-1, which in my case meant j=0 to j=24, which is an awful lot of terms to deal with, so I'm just wondering if there's a different way of dealing with this... (I'm 95% sure my prof didn't want us to use computer programs)
Also, can someone explain what this does? L" + (2l+2 - rho)L' + (n - l+1)L = 0
Haha, I may be really far off but it's tempting to think that maybe that has something to do w ith the question since it has both n and l in it... or... is the generalized wavefunction (the radial part) the "solution" to this equation or something?
It means the answer is (2n+1)a_0
By a hand waving argument, I expect the answer to involve n^2 (and maybe other terms) times a_0.
The classical energy goes as -1/r, and the quantum energy goes as -1/n^2.
Can anyone explain/get me started on how to get to that form of (2n+1)a_0 or another form that involves n^2?
<r>=\int r U^2.
You need integral of xL^2. Using that recursion relation in Arfken (or any other book), the integral of xL^2=(2n+1) times the integral of L^2.
Do you want a pdf of the complete solution for your teacher?
