Find Orig. Speed 3.0kg Mass After Frictionless Explosion
  • Thread starter Thread starter ScullyX51
    Explosion
To find the original speed of a 3.0 kg mass after it explodes into three 1.0 kg masses with given velocities, momentum conservation principles must be applied. The initial momentum (Pi) equals the final momentum (Pf), requiring vector addition to account for the direction of each mass's velocity. The velocities provided include one mass moving north at 9.0 m/s and two others at angles south of west and south of east, necessitating the use of x and y coordinates for accurate calculations. The discussion emphasizes the importance of treating momentum as a vector quantity rather than using simple arithmetic. Properly applying these principles will lead to the correct determination of the original speed.
ScullyX51
A 3.0 kg mass sliding on a frictionless surface explodes into 3 1.0kg masses. After the explosion the velocities of the three masses are: (1) 9.0 m/s north, (2) 4.0 m/s 30 degrees south of west, and (3) 4.0 m/s south of east. What is the original spped of the 3.0 kg mass?
Pi=Pf
P=mv
Pi=Pf
3v= (1)9+ (1)4+(1)4
I know this is wrong. I am confused about what to use for the magnitude and direction of these velocities. would it be 4tan(3) for both of them?
Pi=Pf
3v= (1)9+ (1)4+(1)4
Hi ScullyX51! :smile:
Momentum is a vector, so you must use vector addition, not ordinary addition.
(since there are four vectors, a vector triangle won't be very much use :rolleyes:, so: ) use x and y coordinates. :smile:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
