Exponential matrix problem and Putzer's formula
kamenoss
e^{ \begin{bmatrix} \lambda_{1} & 0 \\ 1& \lambda_{2} \end{bmatrix}t }=\begin{bmatrix} e^{\lambda_{1}t} & 0 \\
\frac{e^{\lambda_{2}t} - e^{\lambda_{1}t}}{ \lambda_{2} - \lambda_{1}} & e^{\lambda_{2}t}
\end{bmatrix}
with \lambda_{1}\neq \lambda_{2}
Could someone solve this for me?
I am no good at maths... with basic knowledge of linear algebra.
It looks like \lambda_{1} , \lambda_{2} are the eigenvalues of a matrix A that solves a differential system. All indications are pointing to Putzer's formula, but everything i have tried failed. Probably i am missing something...
Thanks in advance...
p.s.Sorry for my terrible English
Basically you write out the definition of the exponential:
<br /> e^{x}=1+x+\frac{x^{2}}{2!}+\cdots +\frac{x^{n}}{n!}+\cdots<br />
To compute the LHS of your equation, you will have you figure out an equation for:
<br /> \left(<br /> \begin{array}{cc}<br /> \lambda_{1} &amp; 0 \\<br /> 1 &amp; \lambda_{2}<br /> \end{array}\right)^{n}<br />
and this will give you what you require.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
