Exponential Wavefunction for Infinite Potential Well Problem
7 replies · 3K views
a1234
I am asked to solve the Schrodinger Equation for the "particle in a box" problem (with box width going from 0 to a), but using complex exponentials instead of sin and cos.
sin(x) = (exp(ix) - exp(-ix))/(2i);
psi(x) = A(exp(ikx) - exp(ikx))
psi(x) = A*2i*sin(kx)
psi(x) = A*sin(kx)
Using the boundary conditions where psi is 0, I found that k = n*pi/a, since sin(x) is zero when k*a = 0.
I set up my normalization integral as follows:
A^2 * integral from 0 to a of (((exp(ikx) - exp(-ikx))*(exp(-ikx) - exp(ikx)) dx) = 1
After simplifying, and accounting for the fact that sin(2*n*pi) = 0, I arrived at the following expression:
2*a*A^2 = 1
A = 1/√(2a)
However, once we substitute the above expression for A in the original wave function, we get psi(x) = i√(2/a)*sin(kx).
I would like to know if there is a way to avoid the extra factor of i in the wavefunction. I've read online that the extra i is often absorbed into the constant A, but is there a way around this? I've been told by my instructor that the constant A is supposed to be complex, and that the final wavefunction is supposed to have real components.
That's a perfectly legitimate form of the solution. It's purely a matter of convention and convenience to choose a real normalisation constant. If you need an arbitrary complex number of unit modulus, then ##i## is just as valid as ##1##. As is any other complex number of unit modulus.
Ok. Is there any way of demonstrating that the solutions are equivalent? How does having a complex number in the constant not affect the significance of the wavefunction?
You're looking for solutions to the SDE, which is linear. If ##\Psi## is a solution, then so is ##\alpha \Psi## for any complex number ##\alpha## - which is often called a phase factor.
It's a slightly subtler point that the solutions are physically equivalent. To see this, you could note that the expectation value of any observable is not changed by a phase factor.
In any case, the solutions are mathematically and physically equivalent.
PeroK said:
You're looking for solutions to the SDE, which is linear. If Ψ is a solution, then so is αΨ for any complex number α - which is often called a phase factor.
Although ##\alpha \psi## is a solution for any ##\alpha \in \mathbb{C}##, I suppose it's implied that in Physics that number has to satisfy ##|\alpha| = 1 \iff \alpha = e^{i \delta}##, otherwise ##\int \alpha^*\psi^*(x) \alpha \psi(x) dx## is no longer normalised?
Yes, if ##\psi## is already normalised, then we want to keep it that way.
That's a very important point! In quantum mechanics pure states are not represented by the Hilbert-space vectors ("kets"), ##|\psi \rangle## but rather by the statistical operator ##\hat{\rho}=|\psi \rangle \langle \psi|## (with ##|\psi \rangle## understood to be normalized, ##\langle \psi|\psi \rangle=1##). This shows that two state vectors ##|\psi' \rangle=\exp(\mathrm{i} \varphi) |\psi \rangle## with ##\varphi \in \mathbb{R}## lead to the same state ##\hat{\rho}'=\hat{\rho}=|\psi \rangle \langle \psi|##.
That's very important. E.g., because of this, it makes sense to have half-integer eigen values for angular momentum. Since by definition angular momentum are the generators of rotation, all the half-integer values ##S## following from the angular-momentum commutation relations alone, can provide a valid description of nature, although a rotation by ##2 \pi## changes the wave function by a factor ##-1##. If the wave function itself were representing measurable states, this would make no sense, but as we well know, all the matter around us consists of spin-1/2 particles being fermions.
