Express sum as a definite integral
Bohrok
If n is a positive integer, then
\lim_{n\to\infty}\frac{1}{n}\left[\left(\frac{1}{n}\right)^2+\left(\frac{2}{n}\right)^2+\cdot\cdot\cdot+\left(\frac{n-1}{n}\right)^2\right]can be expressed by what definite integral?
The attempt at a solution
A student I was helping had this problem and I had no idea how to even start. It was a problem along with other basic calc I definite and indefinite integrals, so I'm guessing it has some easy solution that I'm completely missing.
You don't know Riemann sums as approximations to integrals??
I knew it was something simple :rolleyes:
Makes sense; now I just need to figure out f(x)...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
