Expression for induced ε from reducing Loop
A circular loop made from flexible, conducting wire is shrinking in a steady magnetic field, and the task is to find the induced electromotive force (ε) as a function of time. The magnetic flux is calculated using the area of the loop multiplied by the magnetic field, leading to the expression ε(t) = (Bπ(r_0e^(βt))^2)/t. There is confusion regarding the differentiation of exponential functions and the correct application of calculus principles to derive the area and its rate of change. Clarification is provided on the derivative of exponential functions and the need to correctly express the area before differentiation. Understanding these calculus concepts is essential to solve the problem accurately.
quietriot1006
A circular loop made from a flexible, conducting wire is shrinking. Its radius as a function of time is
. The loop is perpendicular to a steady, uniform magnetic field B .
Find an expression for the induced ε in the loop at time t.
Give your answer in terms of
, t, B and appropriate constants.
Magnetic Flux (Φm)=A*B
I(induced) = ε / R
ε =Absolute value of (dΦ/dt)
At first get the magnetic flux using the Area * Magnetic field. Area is (pi)r^2 * B. I use this in faradays law with dt but i don't get the write expression. I end up getting
ε(t)=(B(pi)(r_0*e^(beta*t))^2)/t
I know I am differentiating somewhere wrong but i don't know where.
What's the derivative of
f(t) = eat
Wouldnt that just be a'(t)e^at?
Uh, no. I meant for "a" to be a constant, sorry about the confusion.
If you can express r2 in the form:
r2 = ro2eat,​
and if you can take the derivative of eat correctly, then you'll be able to figure out what dA/dt is.
wouldn't the derivative of f(t)=e^at be just (1/a)e^at? I am not really sure and i don't understand how you were able to square the equation?
No, the derivative is
a eat
You'll have to figure out an expression for A, using A=∏r2, and differentiate it. I mentioned the whole eat thing because the expression for A could be put in that form.
It sounds like you're having trouble remembering calculus ... has it been a while since you took it?
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
