Extremely simple calc problem.
  • Thread starter Thread starter Liu997
Liu997
A particle moves along a curve so that its position at any time t is given by x(t) = (1/12)t^4 - (1/3)t^3 - 4t^2. For which value of t is the speed of the particle the greatest?
It was a multiple choice question so the given answers were t either equals (-2),(-1),0,2,4
Please tell me how you did it cause I would have just took the derivative and put it into my calc to see where it is highest or take the second derivative and set it equal to zero to find critical points and all that jazz.
You want to find where the derivative is a maximum. This is done by computing the critical values of the derivative by computing the second derivative and setting it equal to zero (or of course finding where it is undefined). You should not need a calculator for this. Try to work things out by hand. Calculators take away from the learning experience and the fun.
Why don't you show us what you would do? As a rule we don't give the answers to homework or test problems.
Okay I differentiated to get (1/3)t^3-t^2-8t then plugged it into my ti-83. And saw -2. I'm not going to lie about actually doing it by hand because this wasn't a homework question but one on my test and I try to prevent as much work as possible. I will check it by hand though.
Well I took the second derivative and it is t^2-2t - 8 which easily solves to t = 4, -2
and I still get -2. -_- ughh
(emphasis mine)
:confused: Why on Earth would you do that? I would think that the best thing to do for tests is to show as much work as possible so that one could receive partial credit if the final answer was wrong.
eumyang said:
(emphasis mine)
well it was mostly multiple choice and there was only 1 open ended and my teacher doesn't give partial credit on anything except the open ended. I had like 30 min to do like 20 problems so I figured it would not hurt to just wing it on the calc. eh I don't know
This is the 2nd derivative of the position function, but you're trying to find the maximum value of the speed (magnitude of the velocity function), so t^2 - 2t - 8 is the first derivative of the velocity. The second derivative of the velocity will give you an idea of which of the two values (t = 4, t = -2) gives the maximum velocity.
well I got -2 is that the correct answer to the question?
If the question is at what time is the particle furthest away from the initial position, then it is the first derivative of position correct?
Yes, that's what I get.
You want to find the largest value of x(t), so you would set x'(t) = 0 to find the critical points.
On the other hand, since x(t) = (1/12)t4 - (1/3)t3 - 8t2, since this is a fourth-degree polynomial with a positive leading coefficient, there won't be a maximum value. As t gets larger, the t4 term gets larger and eventually dwarfs the lower-degree terms.
Well this is a bummer
[URL]https://dl-web.dropbox.com/get/photo.JPG?w=06da0233[/URL]
So is this like a poor question?
No, I don't see anything wrong with the question.
[/URL]
Why is that? Also, your picture isn't showing up.
