Calculating Car Mass with Constant Speed on a Bridge
A car traveling at a constant speed of 20 m/s crosses a bridge in 30 seconds and exerts a force of 3000 N. The discussion raises confusion about how a constant speed implies zero acceleration, questioning the validity of the force exerted. Participants suggest that additional information about the situation, such as the bridge's curvature, is necessary for accurate calculations. The question also includes a safety assessment regarding the bridge's weight limit of 5 tonnes. Overall, the consensus is that the problem lacks clarity and may require more details for proper analysis.
Lee80
If a car is traveling towards a bridge at a constant speed of 20ms-1. The bridge takes 30s to cross entirely. The car creates a force of 3000N. Calculate the mass of the car when it is on the bridge.
a=(v2-v1)/t
F=ma
I figured that a = 0 due to the fact that the car is traveling at constant speed.
If a = 0 then isn't it impossible for the car to create a force of 3000N? I am very confused?
Lee80 said:
If a car is traveling towards a bridge at a constant speed of 20ms-1. The bridge takes 30s to cross entirely. The car creates a force of 3000N. Calculate the mass of the car when it is on the bridge.a=(v2-v1)/t
F=ma
First,the speed is expressed as m/s not ms-1.
When does the car create a force of 3000N?On the start of bridge?
Edit:Oh I forgot.Welcome to PF :smile:
a=(v2-v1)/t
F=ma
Hi Lee80! http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
I'm a little confused by the question, too. Perhaps the bridge is curved, maybe semicircular? It is not clear whether this 3000N is a vector sum of multiple forces, including also that force known as the vehicle's weight.
Are you sure you have quoted the question details in full?
Thanks for the welcome! :)
I have written the question exactly the way it is on the page including the ms-1, which i know is supposed to be superscript but isn't it interchangable with m/s? Anyway the only extra info given was a second part to the question which asks "The bridge can support a mass of 5 tonne or less safely. Is it safe for the car to travel across the bridge?"
I don't think the question is correct? I think it needs more info. The question is supposed to be aimed at year 11 physics.
Pity, because it sounded like the basis of a good question: "If the bridge is of level height but curves around the coastline in a semicircular arc, determine that radius of curvature, and the length of the bridge ..." :smile:
Sure is.
There is either too much information provided, or else not enough. :wink: But something's amiss.
I have written the question exactly the way it is on the page including the ms-1, which i know is supposed to be superscript but isn't it interchangeable with m/s?
Yes, if the -1 is a superscript then they're interchangeable.
Use the X2 icon above the message box for superscripts.
m/s is ms-1 .
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
