F:R->R, the fourth derivative of f is continuous for all x
The discussion revolves around a function \( f \) mapping from \( \mathbb{R} \) to \( \mathbb{R} \), specifically focusing on the implications of the fourth derivative being continuous for all \( x \). The problem involves analyzing the behavior of the third derivative at a local maximum where the second derivative is zero.
  • Participants explore the implications of the continuity of the fourth derivative and its relationship to the continuity of the third derivative. There is an examination of Taylor's series expansion around a local maximum and the significance of the first and second derivatives being zero. Some participants question the necessity of considering different cases for values approaching the local maximum.
The discussion is ongoing, with participants providing insights into the Taylor series and its implications. There is a focus on understanding the behavior of the function near the local maximum and the potential signs of the third derivative, though no consensus has been reached on the conclusions regarding \( f'''(a) \).
Participants are navigating the constraints of the problem, particularly the conditions of local maxima and the implications of derivatives being zero. There is a recognition that the continuity of derivatives plays a crucial role in the analysis.
sdff22
F:R-->R, the fourth derivative of f is continuous for all x...
Suppose f is a mapping from R to R and that the fourth derivative of f is continuous for every real number. If x is a local maximum of f and f"(x)=0 (the second derivative is zero at x), what must be true of the third derivative at x? Fully justify your answer.
my thinking so far is that since the forth derivative is continuous for every real number, it should exists for every real number. If the forth derivative exists, it means that the third derivative is continuous for every real number (since we know that if derivative of f exists at a point x, then f is continuous at that point). so all I know is that the third derivative is continuous at every point including point x.
You should know more than that. You haven't used the fact that you are at a local maximum and that f"= 0 there. The Taylor's series for f(x), about x= a, is f(a)+ f'(a)(x-a)+ f"(a)/2 (x-a)2+ (f'''(a)/6) (x-a)3+ higher order terms. If x= a is a local maximum then its first derivative, f'(a), is 0 and you are told that the second derivative, f"(a) is also 0: f(x)= f(a)+ (f'''(a)/6)(x-a)3+ higher order terms. For x sufficiently near a, we can ignore those "higher order terms" in comparison to f(a) and (f'''(a)/6) (x-a)3. Think about what happens if x is slightly larger than a and what happens if x is slightly larger than a.
Thank you very much for he help.
So should I consider different cases like:
1. x-->a+ (i.e. x-a>0), then if f(x)>f(a)==>f"'(a)>0
if f(x)<f(a)==>f"'(a)<0
and the same argument for x-->a- (i.e. x-a<0)
but I am confused about this fact that having both first and second derivative equal to zero tells me that when x gets very close to a, then f(x) gets very close or equal to f(a). Knowing this, doesn't mean that f"'(a)=0 using the Taylor expansion of f(x) you have written?
Thanks again,
No, it doesn't. It means that f(x)= f(a)+ f'''(a)/6 (x- a)3+ higher power terms. Putting x= a tells you nothing about f'''(a) because the (x-a)3 term is 0.
Now, if x is slightly larger than a, what is the sign of (x-a)3? What if x is slightly smaller than a?
