Factors affecting the resonating frequency of wire
In summary: Material properties like density or the elastic modulus might play a role in determining the resonant frequency of the wire.
revan
I have been tasked with a physics project at school, to investigate what factors affect the resonating frequency of a piece of wire. We arent told anything about the experiment, its a kind of research on your own thing. I know that the resonating part means the frequency at which the piece of wire will vibrate, but its how to test this by experimental means that has me a bit stumped. I know that resonance is usually about sound, so i guessing that to make it vibrate it will require something to generate sound of a certain frequency, perhaps a signal generator, or something like a tuning fork. Would i be correct in saying that perhaps tuning forks of certain notes could be one of these 'factors'. I have to devise several methods of carrying out this experiment, so any of you guys have any ideas??
By 'factors' the question means 'properties of the wire'. The resonant frequency of the wire is a function of the properties of the wire, and not of external conditions. You want to devise a set of experiments that vary different properties systematically and record the change (if any) in the resonant frequency, as a result.
Do you understand what the resonant frequency really is ? Can you come up with a list of properties that you think might affect the resonant frequency ?
I think by resonant frequency it means the frequency of sound that makes the wire vibrate, its not something covered in my course, its something that I have to learn from textbooks and reference books, but it goes into far more detail than I can make sense of.
I plan to carry out the experiment using a vibration generator, which will be attached to the wire. The wire will then be attached to a wheel of some sort that will allow weights to be attached in order to keep the wire tight.
Regarding the factors, I have 3 so far, they are:-
1) Length of wire used
2) thickness
3) tension the wire is under, varied by increasing the mass of the attached weights
Any other suggestions regarding this?
Thanks for any feedback given in advance.
how about the kind of material?
Steel wire is easy to get (at music stores);
Copper wire is also easy; aluminum should be findable.
(Nylon fishing line isn't technically wire, but resonates.)
If you use steel wire, a nearby magnet might influence it.
A magnet might even influence an aluminum wire's resonance.
have fun!
2) thickness
Good going, so far. What about material properties like density or the elastic modulus? Might any of them play a role ? Worth giving it a shot ?
Thanks for the suggestions, I will check some of them out to see which are the most viable.
What is resonating frequency?
Resonating frequency is the natural frequency at which an object vibrates when it is disturbed.
What factors affect the resonating frequency of wire?
The factors that affect the resonating frequency of wire include its length, thickness, tension, and the material it is made of.
How does the length of the wire affect its resonating frequency?
The longer the wire, the lower its resonating frequency will be. This is because longer wires have a greater mass, which makes them vibrate more slowly.
Why does the thickness of the wire matter for its resonating frequency?
The thicker the wire, the lower its resonating frequency will be. This is because thicker wires have a higher mass, which makes them vibrate more slowly.
How does the tension of the wire impact its resonating frequency?
The higher the tension of the wire, the higher its resonating frequency will be. This is because higher tension makes the wire stiffer, which allows it to vibrate more quickly.
